Old 02-08-2006, 08:40 PM
89civic_sedan 89civic_sedan is offline
Idle Problems Worse
OK when my car use to bounce from 2 to 3 rpms now when i hit the gas it goes up to 3rpms and then goes down to 1 and back up to 2 then eventualy go dead why is this. Could it be the timing?
Old 02-08-2006, 11:14 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Idle Problems Worse
Vaccum leak man....Id almost put money on it, take a squirt bottle and spray all of your vaccum lines, and around the manifold seals. If it stops for a second when you spray then you know you've got a leak....
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-09-2006, 06:16 AM
Well can you get me a picture or diagram of the vaccum lines and dont say its the little rubber lines cause thats no help to me.
Old 02-09-2006, 05:24 PM
FrodoGT's Avatar
I couldn't find a diagram but I did find this. http://crxresource.org/modules.php?n...rticle&sid=117
And the vaccum lines are the black rubber hoses attached to the manifold, they are mostly grouped together on the firewall side of the manifold.They are small, and black....
Current project:
Rio Red 91 hatch.
Old 02-09-2006, 06:56 PM
well thanks ill attempt on saturday.
Old 02-10-2006, 04:04 PM
Well i poped the hood and saw one black small hose on the driver side of the manifold so i pulled it off while the car was running and then it almost died. So then i went the the other side and saw 2 small black hose pulled the top one off and it idled really high pulled the pottom one off and did the same thing as the top. Now what do i do.
Old 02-10-2006, 04:06 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Why are you pulling hoses? You're supposed to spray them with water. If the problem corrects itself when you spray a hose then that hose has a hole in it. You can use duct tape temporarily over that hose until you replace it. Don't pull your hoses off cuz you'll just mess it up...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 02-10-2006, 04:13 PM
ok but the hose that im messing with is the right hose aint it
Old 02-10-2006, 04:36 PM
Well i sprayed them and nothing happend it stayed the same. The idle kept bouncing up and down. So now what do i do?
Old 02-10-2006, 05:50 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
try using some soap with the water then when the air leaks out you'll see the bubbles. I used this when my accord had idle problems.
Old 02-10-2006, 06:08 PM
vorked1260 vorked1260 is offline
Send a message via AIM to vorked1260
soo i have a sedan to and i ahd the same proble and when i started looking around...i found a hole turns out it was not that there was a leak at the poulation control valve....right in the back
Old 02-10-2006, 06:54 PM
I will try this towmorrow.
Old 02-11-2006, 09:48 AM
Well i tried the soap and water thing and didnt see any bubbles. So now what.
Old 02-11-2006, 11:09 AM
Hybrid1990crx's Avatar
take of your iac and clean it. that never works though LOL.
does your car idle ok when its cold?
Old 02-11-2006, 12:20 PM
No its cold now and its still bouncing around.
