Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-08-2006, 05:31 PM
cruisingclassic cruisingclassic is offline
Coolant System Trouble?
So I have been having this problem consistently for the last 2 years. My car tends to overheat in the summer, quickly when it is really hot, or slowly when i am travelling longer distances and the weather is mild. I have replaced the fan clutch, the thermostat, and have had it looked at by several mechanics, there appears to be no pressure problems or leaks and the everything else seems to be working fine other than the fact that it overheats (only in the summer). Any suggestions?
Old 02-08-2006, 06:30 PM
AgnosticFront's Avatar
AgnosticFront AgnosticFront is offline
Re: Coolant System Trouble?
Not a mechanic or anything but, have you tried using that 'super coolant' stuff that they have at auto parts stores? thats what I would try...
Old 02-08-2006, 07:08 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Sounds to me that your cooling system doesn't have the capacity. You might need to have the radiator rodded out. Can you give some specifics, such as engine size, car year etc?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-08-2006, 07:36 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
maybe try a hi-flow waterpump
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 02-11-2006, 08:15 PM
TommySS TommySS is offline
If your was an 80s model, your radiator is plugged up (hence reduced cooling capacity). It's also a 2-row core, and I went to a 3-row. Worked great for many years.
I also installed an external trans cooler (in series) to take some of the stress off the cooling system.
When I swap engines out (I keep saying I'm gonna do that, but the engine simply won't die on its own), I plan on going with an engine oil cooler as well.
Old 02-13-2006, 11:26 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I'd go with the bad radiator diagnosis. I have never had a Caprice overheat on me, it's not in the car's nature to do so. The radiator might be full of stop leak or some other cooling additive. When you get a new one (check out NAPA they got good price$) compare the weight of the old one, if the old one is a lot heavier, it was definitely clogged up.
Bob
Old 02-22-2006, 06:31 PM
cavie 00 cavie 00 is offline
Cool Re: Coolant System Trouble?
gotta 96 caprice 9c1 had the same problem in mine in the summer time pissed me off cuz i couldn't take long trips. anywayz the caprices have a lil weak spot which is the coolant box, it breaks easily. mine had a hair line crack but it sipping out alot of pressure. got it changed an it worked fine.check the radiator also. if urz was a 9c1 the rad fail that easily.
good luck!
Old 02-22-2006, 06:32 PM
gotta 96 caprice 9c1 had the same problem in mine in the summer time pissed me off cuz i couldn't take long trips. anywayz the caprices have a lil weak spot which is the coolant box, it breaks easily. mine had a hair line crack but it sipping out alot of pressure. got it changed an it worked fine.check the radiator also. if urz was a 9c1 the rad **shouldn't** fail that easily.
good luck!
