Old 02-08-2006, 06:22 PM
dampontiac dampontiac is offline
Exclamation 97 gr am trouble
So 97 gr. am. 160,000 2.4l quad4. finished replacing the head gasket timing and even the heater core.
drove it around then let it sit for about 2 hours and a huge puddle of oil ws on the ground under the car. also noticed a trail of oil on the driveway and into the garage.
i am so sick of this dam engine. it was way over thought when gm got together and built it.
so any help would be great since i am at wits end here.
THanks to all!!!!
Old 02-08-2006, 06:29 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 97 gr am trouble
Welcome to AF!!
There are a couple of items that could cause this first check to make sure that the oil filter is tight and the seal is intact. If that checks out check to see if you can locate where the oil is coming from. Worst case scenerio is that the rear main seal has gone bad and will need to be replaced. If you locate the area post again and someone will help you as much as possible.
Old 02-15-2006, 07:59 PM
manjed manjed is offline
Originally Posted by GTP Dad
Welcome to AF!!
quad 4 is a 2.3 not a 2.4
Old 02-15-2006, 08:21 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
4 cyl grand am's 92-95 had the 2.3, in 1996 it was changed to a 2.4. They both have their strengths and weaknesses. As for the oil leak, did you replace the gasket on the timing cover? Its a rubber coated gasket, I have seen a few where someone changed the head gasket and didnt' change the timing chain cover gasket because they didn't think they needed to.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 02-18-2006, 02:12 PM
Vault4CMA Vault4CMA is offline
Send a message via AIM to Vault4CMA
well, i know it'll be a one year downgrade but i'll give you a good deal on my 96 pontiac grand am, if you want to buy it, im trying to sell it cuz i want to buy a bike.. IM me at locaChik247 or message me back on here
