Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 02-08-2006, 02:41 PM
kmartin1794 kmartin1794 is offline
Angry bronco wont start
I just bought 89 bronco. on the way home it overheated, so i replaced the water pump after finding a hole in the bottom of it then it oveheated again after 15 miles so i found the thermastate was stuck closed, i pulled it out then it wouldnt start. after i towed it home I replaced the coil, and the modual thats on the distributer and now i have spark but the engine turns over real slow. It has a new battery and silonoide. I'm getting back fire whae its turning over so i know the timing is off but whats the problem with it turning over slow
Old 02-08-2006, 05:07 PM
Truck Truck is offline
Re: bronco wont start
Check the oil. I bet it has the consistency and color of a milkshake. (Hot Fudge, not chocolate.) You probably have a blown head gasket. Once you replaced the water pump-you let in all kinds of water/coolant into wherever the head gasket was bad. I'd say take off the heads, clean them, mill them, get a new set of gaskets.
Old 02-08-2006, 08:38 PM
I thought about that but the oil is a dark brown like its old oil not quite black I am going to try to jump it off another car and see if that helps with the slow turnover. If there is anything else that it could be i could use the help. thanks
Old 02-09-2006, 08:50 PM
OK I tried to jump it off another car and that diddnt help. could it be a weak starter or something else? this thing is pissing me off and I dont know what to do about it HELP!!!!!
Old 02-10-2006, 09:32 AM
Well, it sounds like, to me, you've done everything but replace the alternator. That could be your boggle. That's where the voltage regulator is, and it engages when you start the vehicle. Battery->Solenoid->coil->Alternator->Battery. If I recall correctly.
Old 09-29-2006, 12:13 AM
lilmike571 lilmike571 is offline
ok when replaced the piece on the distributor did u take it out? when timming is so far off one way the engine will free spin or in your case the other way it will turn over slow like it is hesitating right. try that and see what happens
Old 09-29-2006, 04:04 AM
Pete33Vt Pete33Vt is offline
That sounds about right. If your timing is way off it will cause slow turnover.Also check all wire going to starter, and at starter. If they are bad or really coroeded you will not get the full juice to the starter. But I would lean more to the timing.
