Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 02-08-2006, 12:37 PM
Guam Guam is offline
Talking 93 Ford Aerostar Brake & antilock lights.
My brake light and RBS light are always on. I changed the differential sensor and bleeded the brake system with new fluid, but no help. What would case both lights to stay on.
Old 02-08-2006, 12:44 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: 93 Ford Aerostar Brake & antilock lights.
I don't know about the brake light but my moms ABS light is always on, Nobody knows why.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-30-2007, 01:06 PM
1car3vans 1car3vans is offline
I would also like to know the answer to this questin because I have the exact same problem.
Old 12-17-2007, 01:51 AM
knelleken knelleken is offline
in order to diag. the issue,you need to retreve the trouble code
Old 12-19-2007, 09:56 PM
PatrickWK PatrickWK is offline
I have a 95 with the same problem. Have had it for years. Every year it passes inspection and the mechanic said there were no problem codes. Just kind of a fluke though I'd like to get rid of it too. I think I tested the ABS last year by stomping on the brakes real hard and the ABS engaged so I just let it go.
Old 10-11-2008, 11:37 AM
chulok56 chulok56 is offline
A friend of mine who had a Mercury Villager Changed the Tie Rod ends and then the light went out for him. I am not sure on the Aerostar. But check into it. Ask a Ford Service Dept. They may know.
Old 10-12-2008, 12:39 PM
65val 65val is offline
Probably the clockspring in the steering column.
Old 12-05-2009, 12:19 PM
dslpwer dslpwer is offline
If you are having ABS lights going off, have someone check to make sure no wires are broken behind the wheels on the caliper. This is a problem with numorous makes and models, it's all the same. Doent cost to look and something you could do yourself.
Good luck and let me know if this was any help.
[email protected]
Old 12-05-2009, 07:52 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
The long as your van brakes correcly, why do you care?
Your ABS are not working, but it's not important at all. In my 2 cars, I disabled the ABS and I find that the cars are more controllable. It may be a bad ABS sensors...
For the brake light, it normally indicates low brake fluid level/pressure. The long as the level is good and the braking is normal, you shouldn't care of this annoying red light.
Pull the handbrake lever and release it to be sure that it's not the handbrake indicator.
Check alternator voltage. Low alternator voltage can cause the brake light to turn on.
Check also for bad electric contact in the ABS module.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
