Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-08-2006, 12:31 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
need help! ASAP
Well, Im driving down the road to work, and I was about to shift at about 6500rpms, and I heard a pop noise, and my car just died. Timing belt is fine, I noticed my o2 sensor wire was burned up so I replaced all the wires, and it wanted to start for half a second, then died. Im thinking its the o2 sensor.
Injectors are getting voltage along with the o2 sensor connector. What fuse would it have blown because all of them are fine. And I know the FP is fine too, I can hear it when I crank the car.
I need my car tomorrow for school, so I need to get this shit fixed today.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 02-08-2006, 02:05 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: need help! ASAP
Any smoke or anything? Do you have any type of logger? Cause you can get o2 voltage from that to see if the sensor is bad. How does it sound when it runs?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 02-08-2006, 03:32 PM
turbotalon95 turbotalon95 is offline
Re: need help! ASAP
is the timing set right. you could have jumped a couple teeth on the cam sprokets. the thing that scares me is that that popping noise could have been a piston hitting a valve or something like that. check the timing. here are some other things to check. check your spark, check your fuel, and check the vaccum then post what you found out and ill try to help you some more. also what year make and model is your car.
Old 02-08-2006, 03:40 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: need help! ASAP
It says in the sign:
95 Eclipse GS-T
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-08-2006, 10:22 PM
Re: need help! ASAP
Well, right now its at my community college and my teachers will help out with it. Wheres the best place to buy a new engine though, Im thinking instead of dealing with this one, I can drop it and put a new one in within a day, then rebuild this one and put a lot of power into it.
95 Eclipse GS-T
Currently:
Soon lol
Old 02-08-2006, 11:53 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: need help! ASAP
Uh.... are your teachers like auto mech If so your going to probably need more than a day to pull and then drop another one in there.. if thats what you were saying..
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 02-09-2006, 12:02 AM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Re: need help! ASAP
First you need to check all of your I/C piping, this happened to me and all i did was blow the coupler apart on my LICP. Check it and let us know.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 02-09-2006, 12:18 AM
ez1286's Avatar
Re: need help! ASAP
Try doing a compression test, if it's something electrical a new engine might not help.
Old 02-09-2006, 04:02 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: need help! ASAP
i agree with ez...a compression test will likely tell you whether you bent any valves or not (if that's even the case) but check your i/c pipes too. but had the i/c pipes come off, you'd likely hear a whooshing of air when the turbo spools up. car-part.com has used engines if you don't feel like speding all the money on a new one.
95 Talon TSI AWD
97 Eclipse GST
