Old 02-08-2006, 11:22 AM
67ROCKETPOWER 67ROCKETPOWER is offline
Oldsmobile Power Blocks 400 & 455
THE BEST 455 EVER! NOT OPINION, BUT FACT!
IF YOU CAN FIND A 1968 TORNADO, YOU ARE SET.... FACTORY NODULAR CRANK, FACTORY WINDAGE TRAY (THE ONLY KNOWN VEHICLE TO HAVE ONE), HIGHEST NICKEL CONTENT IN THE BLOCK CASTING, AND THE EVER FAMOUS "C" HEADS. DID YOU KNOW THAT THE 1968 HURST OLDS ENGINE WAS A H.O. 455 FROM A TORNADO?
THE BEST OLDS BIG BLOCK EVER IS MY EVER LOVED 1967 400 BIG BLOCK!
1967 442's CAME WITH THE 4" BORE AND 3.98" STROKE, WITCH MAKES THE ENGINE WHAT THEY CALL SQUARE.... SO I HAVE ALL THE BOTTOM END TORQUE OF THE BIG BLOCKS, WITH THE HARDLY EVER FOUND - HIGH RPMS TO PRODUCE MORE HORSEPOWER.
MY STOCK '67 442 W/400 ENGINE (NOT W30) WITH M21 4SPEED, AND 3.91 POSI CAN STEP ALL OVER MY STOCK '69 HURST OLDS W/455 ENGINE WITH HURST TURBO 400, AND 3.91 POSI - THE '67 HAS BETTER 60' TIMES, AND BETTER ET's... WITCH MEANS BETTER OF THE LINE AND FASTER DOWN THE TRACK.
HAVE FUN DRIVING, DRIVE AN OLDS - GO FAST,
AL
