| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
budget stroker vs 4g63
How does a 4g63 compair to a budget stroker(4g64 crank, 1g rods 2g pistons) as far as perfomance relaibility strength?
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
Re: budget stroker vs 4g63
Will the normal 2g pistons work for the stroker? I was under the impression that you would need "stroker" pistons. I would assume that a stroker would hold up just well as the normal rebuild, but you would have a little more power, but then you probably wouldnt be able to rev quite as high. Also, spool time is taken down by like 500-800 rpms IIRC.
why wouldnt normal pistons work? I dont know what the difference would be
The 2g pistons wont work. You need stroker pistons because the sroke is longer and the top of the piston will hit the head. On stroker pistons the pin goes through higher if that makes sense, so it doesn't go as high in the cylinder.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
as far as reliablitiy goes, it's just like any other car, don't beat the piss out of it and it will last. you'll be able to spool up a larger turbo faster with the stroker, but you'll need the stroker crank, special rods, and special pistons. if you're already planning on a re-build it might be a good investment if you're going to go large turbo down the road, but if your not going for monster power, i'd save the money and go with a regular rebuild. just my $.02
Any set of 1g rods will work, you dont need special ones.
6bolt Stroker. G4CS crankshaft $463 New from my work, 1g rods (free) machined with ARP bolts $40. Weisco stroker pistons $350 Ebay.
DSM geek |
Fuck you scottsee
I'm more then happy to extend my disscount to my fellow AF's. None of you broke f****** can aford on though!
DSM geek |
scottsee i might be hitting you up on one of those G4CS cranks in a couple months if the offer is there. when school is done i'm gonna start on the car again.
ight
DSM geek |
