Old 02-08-2006, 06:50 AM
seamelol seamelol is offline
chugging along
I have a 95 grand am with 189,000 miles and as I was driving it up a hill at 60mph it felt like it was chugging along once i accelerated (pedal all the way down) it stopped but would continue again hill after hill. any ideas will help a lot
Old 02-08-2006, 12:14 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: chugging along
this an automatic or manual?
If its an auto check the trans fluid level and if its dark and smelling funny. Could need a fluid and filter change.
But if its a manual, check the fluid level on the clutch.
This could also indicate a faulty/dirty IAC, or a vacum leak on the intake, or some thing to do with the fuel system. Like a fuel filter cloged or the fuel pumps weak(check fuel pressure).
Hope this narrows it down, lets us know! And Welcome to Automotive Forums!
1999 Grand Am SS 3.4 OHV
Old 02-09-2006, 05:28 AM
Hoags's Avatar
Hoags Hoags is offline
Re: chugging along
Since it is acting up so much on the hills, I would suspect that it would be a fuel filter. It sounds like the classic symptom for a clogging fuel filter. I would start there, but I would also check the other items listed by Xeroinfinity.The replacement filter is not too expensive, if you are going to do the job yourself you will most likely need a special tool to release the filter from the fuel lines. If you decide to do the job yourself be very careful it is a messy job and you will probably get gas on yourself.
Even if it turns out that the fuel filter is not the main issue, with 189,000 miles it would be a smart thing to so simply because of the number of times you have had to put gas in the tank.
I am recomending this on the assumption that the fuel filter could be the original filter.
Hope this helps,
