Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-08-2006, 01:56 AM
lengnoou lengnoou is offline
93 camry chip
on my 93 camry, theres a plug thingy under the steering wheel that looks like its missing some kind of chip that goes there...i bought it like that, but i didnt know that that part was there till i got home with the car...i called the previous owner, but he said he had no idea either...he said it was probably a security device or something like that....what is it?
Old 02-08-2006, 05:04 AM
galeff galeff is offline
Re: 93 camry chip
I believe that could be one of the OBD (On Board Diagnostics) connectors located near the steering column but coming from under the dashboard. This would be an empty connector where a shop would plug in a diag device. There is also one located under the hood on the passenger side near the wiper motor (if memory serves me correctly) but it is rectangular with a cover on it.
Hope that helps. If that doesn't sound right I can look closer at my 93.
Old 02-08-2006, 08:11 PM
InstallTech's Avatar
InstallTech InstallTech is offline
Re: 93 camry chip
I think I may know what you're talking about. I've seen them before...they're just flat with one row of pins. They're a basic starter disable system that usually requires a "key" that you insert into it to start the car. If you can start your car without that, it's more than likely been bypassed...so I wouldn't worry about it.
I reject your reality, and substitute it with my own.
