Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-08-2006, 12:29 AM
325adam 325adam is offline
1983 Burban Rear Window.. Help
I just pulled my burban out from being retired for a little over a year.. I rolled the back window down, and now cant get it to roll up by sticking the in the tailgate or the switch on the dash... Please help
Old 02-08-2006, 07:41 AM
Old Dave Old Dave is offline
Re: 1983 Burban Rear Window.. Help
My 86 Suburban had a switch inside the tailgate on the right side that was intermittent at times and wouldn't let the window roll up. Open the tailgate up and look inside where the latch is on the right side and you will see it. It has a metal plunger that depresses and closes the switch when you close the tailgate. If this switch isn't closing and making contact, the window will not operate. I sprayed mine with contact cleaner and it fixed it right up.
1970 GMC 2WD shortbed fleetside
1984 Olds Delta 88 (won't die)
1997 GMC Suburban K1500 W/5.7L Vortec
2000 Dodge Ram 1500 4WD Shortbed Ext. cab
1998 Chevy K2500 W/5.7L Vortec
2002 Harley Custom Chopper
Wife is a late 1951
Old 05-21-2006, 08:03 PM
str8iiiiiid str8iiiiiid is offline
i have an 83 suburban that had this exact problem.It would roll down but not up...i unplugged said plug in righthand area of tailgate ,clipped the head off the plug and spliced them together...problem solved
Old 05-22-2006, 09:21 AM
idmetro idmetro is offline
That will certainly allow it to operate but I would be reluctant to leave it that way. With my luck I would get the tailgate not quite shut all the way; roll the window up only to have it crash into the frame and fill the back of the burb with glass crumbles. Much better to get a replacement switch.....
