So I was driving home from work tonight and all of a sudden I start hearing some crazy pop from my engine and I have trouble accelerating. I pulled over and popped the hood and found that one of my plug wires had popped out, so I pushed it back in firmly and got backon my way. It happened again so I repeated the procedure. So now I'm home worried as sh*t about this problem. Does anyone know what the problem may be and how I can fix it?
Re: Engine Trouble... PLZ HELP!!!
sounds similiar to the problem i had with my 92 civic hb. cept i don't recall hearing a pop, but i was on the highway so there could have been a pop. but when i got into the city, i came a light and started to go and omg it took so long to get up to speed limit, so i took it to the shop and they looked under the hood and i had a couple fried spark plugs, and under further inspection they found i had no compression in 2 of my 4 cylinders. so i got an engine ordered in from japan to get put in my car.. hopefully you didn't have the same problem
So just one of your wires keeps popping out? What kind of wires do you have? Possibly try bending the clips inside closer together to grab the top of the plug better.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower. "How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen) Emily is amazing, and she messed with my sig AGAIN!
Check you're spark plug where the wire pops out. Make sure that the plug is tight. Crank the enigine while that wire is out and put you're hand over the hole for the spark plug. If you feel air then you may need to replace the spark plug or you may have a bigger problem.
