Old 02-07-2006, 11:02 PM
gmcgotnothingonme gmcgotnothingonme is offline
Question silly s10 ac compresser
so i just bought a 1995 s10. with the 2.2. It ran fine for a week but has now developed a terible grinding noise. it has been parked scince then. but anyway it is comming from the ac compressor all of the time. there is also mettal shavings coming off of the ac compresser. is this the clutch on it or is it the whole unit.
Jon
Old 02-08-2006, 01:13 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: silly s10 ac compresser
bi pass it, my 98 came w/o ac on it so get the non ac belt, its most likly the bearing in it which has chewed up the hub
Old 02-17-2006, 02:40 PM
brcidd's Avatar
brcidd brcidd is offline
Your clutch is dragging- borrow the remover tool from autozone- back the driver out to .020" air gap and be happy- this is caused by corrosion build-up behind the springs of the clutch driver- seen it
Old 02-19-2006, 11:33 AM
Cam1959 Cam1959 is offline
Some oil dropped top center into gap between moving and none moving part will quiet it for while until you adjust it or bypass with non a/c belt. Atleast it worked for me.
1983 S10 4WD carbed 2.8L automatic w A/C
