Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-07-2006, 09:28 PM
DenisM DenisM is offline
tire size confusion
im looking for some new tires for my 87. i cant decide between the 245/60 15 or 255/60 15. a tire guy i deal with said 245/60 is the largest you can fit on caprices up front without rubbing, but i saw on here that you can get 255's. do the 255's rub?
Old 02-07-2006, 10:39 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
Re: tire size confusion
not on my '89
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 02-08-2006, 12:20 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Never had a rub problem running 255/60s on my Caprice, either.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-10-2006, 12:57 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Somewhat related to your question, I was told the same thing for my 1964 BelAir. I still went ahead and put 245/60's on it without any rubbing or other problems, and this car sits lower. I had the same issue when getting new tires for my 1995 Roadmaster. I wanted to go back to the original 235/70 that were supposed to be on it, instead of the 225/75 that the previous owner put on it. I was told the same thing about the rubbing, yet again I went with my instincts and put the 235's on it with no problem. One of the garages I used to work for had a complete tire shop out back and speaking from experience, the guys were told by the boss to try and stick with what the book recommends even if there are other sizes that may fit. This is a form of "covering their asses" as we used to call it, so they wouldn't be responsible if problems occured after the customer left the shop with a different sized tire than was recommended in the book.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 02-10-2006, 01:56 PM
Cyrix_2k's Avatar
BTW, the 255/60's are the same diameter as 205/75's so your speedometer will still read correctly
Old 02-10-2006, 09:27 PM
BZR77CHEVY BZR77CHEVY is offline
I'm running 255/60 15's on my 77 (inner fenders are the same up to 90) at all corners and never rubbed even under hard cornering and braking, loaded or unloaded, and even hitting bumps, ect. The Tech is just reading it out of a book.
Old 02-10-2006, 10:03 PM
smokinhydes1 smokinhydes1 is offline
I had a look I wanted, bought new Chevy Corvette Rallies thru a local biz, and I installed 235/60/15 on the front, 275/60/15 rear Firestone Indy 500's. This is on my 89 Brougham. No probs whatsoever. It has new gas shocks from two days ago, I don't know if that affected the clearance because of better rebound or not. But it handles great, and looks fantastic. To go with 245 on the front <given the supplier I have, I run an auto repair shop> I would have been forced to go to the Disastercrafts <Mastercraft, Bastardcraft> which just ride like Tractor tires and wear like Ice cream. I don't know how to upload a photo, but I can flip you one on regular e-mail. And hey, what are the factory wire caps in great shape with all the hardware worth?
Old 02-10-2006, 10:08 PM
I forgot to mention, the 235's up front help with the "snowplowing" effect...whereas I think <don't KNOW, but think> the 255's higher sidewall would be more susceptible to roll in corners. The balloons on the back are handled nicely by what is in effect a 4-link rear end.
Old 02-11-2006, 12:33 PM
Cyrix_2k's Avatar
I never had a problem with my 255's on shocks that were shot to hell... though the car rides/handles/etc so much better with new shocks Also, if I were you, I'd get 255's up front and 275's out back. For some reason, the tires on the back of my car look smaller than the ones on the front; 275's should fix that.
Old 02-11-2006, 12:59 PM
It's weird you say that, the 235's look every bit as big as the 275's on my car, you'd have to get a tape out if there weren't numbers on the sides
Old 02-11-2006, 02:53 PM
studious03 studious03 is offline
not exactly current topic but i have a similar question how wide can i go on the back of my 92 caprice i have "skirts" on the back thats why im asking. current size is 215/70/15 all around
1993 Toyota Camry LE 2.2
1992 Chevrolet Caprice 5.0
1995 Jeep Grand Cherokee Limited 5.2
