Old 02-07-2006, 10:10 PM
ude_loose's Avatar
ude_loose ude_loose is offline
Send a message via Yahoo to ude_loose
temperature gauge goes up & down
my cavalier's temperature gauge stays between 1/4 and 1/2 when driving around in cold weather wether its in the street or in the highway, but for some odd reason when the car is parked or in drive but fully stopped for a couple of minutes the gauge goes just a little over 1/2 qucikly this did not happen before, i also have never heard my fan go on but it has been tested and works so i was wondering if this could be due to a bad thermostat...
Old 02-07-2006, 11:14 PM
GeishaGhoul GeishaGhoul is offline
Re: temperature gauge goes up & down
I've experienced this too, but nobody (my old mechanic included) has been able to pinpoint the problem.
Old 02-08-2006, 12:45 AM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
What usually runs that is a faulty temp sensor. I am sure sure where it sits at on the Cavalier, but I had a chevy Lumina that did that and I replaced the sensor and it seemed to fix it. Also you may want to check the electrical cooling fan relay
Old 02-12-2006, 04:28 PM
94VL 94VL is offline
Mine when warm hunts between 1/4 gauge and 1/2 gauge.It will come up to nearly 1/2 gauge and then it rapidly drops down to just above 1/4.Then it slowly starts its march back to 1/2 again.I am going to have to hook up the OBD tool to it when its hot to see what the actual temp sensor/computer is claiming the temp to be.I am thinking its a thermostat acting up.Sorta sounds like the thermostat sticks closed and then rapidly opens up,then when temp drops below a certain point it closes again.The temp sensor was replaced,and aside from the OEM one being covered in a slimy substance,there was nothing wrong with it.Car does not overheat and I have yet to see past the 1/2 gauge mark,and have never heard the radiator fan come on.
Old 02-12-2006, 11:25 PM
ude_loose's Avatar
yea dat sounds like my problem to, i hav had the thermostat gasket replaced once and i dont know if the thermostat went bad and neep to replace it i still need to check that out...
Old 02-13-2006, 02:25 AM
CavLCD128 CavLCD128 is offline
Send a message via AIM to CavLCD128
my temp gauge used to work its way up to 1/2 and just sit there but lately i have noticed its moving up a notch every couple months....its slowly workin its way up there...its like 2 or 3 nothces away from 3/4ths....any help is greatly appreciated...
ThE neW wHiP:
