Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-07-2006, 08:27 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Starting problem
Well, Im just flat out confused now...When I go to start my car sometimes, I have to hold the pedal to the floor to get it to start and fire, but other times I just have to turn the ignition and its fine. My auto teacher said it might be a faulty tempture sensor. A friend said maybe dirty or clogged injectors. I plan on taking it to autozone when I can to see what codes its throwing besides the 2nd o2 sensor. All I can remember is a long time ago the car threw a code and I didnt think anything of it. Also, sometimes it starts up then dies and I have to give it a little gas for a secon or 2 to get it to idol.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 02-07-2006, 08:44 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Starting problem
The 2nd O2 alone wont throw a cel. It's hard to say but i'd take it to autozone and get it checked soon cause who knows what it could be.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 02-07-2006, 09:08 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
The downstream o2 sensor would throw a code if either the cat was removed/not working, or if the o2 sensor was not installed. It would only throw a code in closed loop mode and the code would be a bad cat code. If it was a bod coolant temp sensor it might cause your problem but I would think it would be more constand than what you described
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-07-2006, 09:10 PM
ez1286's Avatar
My cat not existing never threw a cel on it's own but if i check the dtc's with dsmlink it's there...
Old 02-07-2006, 09:40 PM
Yea Ill have to take it tomorrow when I get time, Ill let everyone know what the cel is.
95 Eclipse GS-T
Currently:
Soon lol
Old 02-07-2006, 10:39 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
guys guys guys...problems go in the problem diagnosis sub-forum...pah'leez!
The daily driver. The weekend cruiser. The lazy shop hog.
