Old 02-07-2006, 08:05 PM
ace13579 ace13579 is offline
engine problems
I just bought a 99 grand am Gt and if I try to accellerate fast it seems To stay between 2000 and 3000 rpm and lacks power
Old 02-07-2006, 10:08 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: engine problems
Welcome to the forum. Are there any other symptoms? (sounds, smells, ect.)?
It could be a blocked catalytic converter, exhaust manifold leak, clogged fuel line, many many different things. Are there any symptoms and/or engine codes? (is your check engine light on)
Old 02-07-2006, 11:39 PM
Re: engine problems
there is no smell and no leaks on ground also the exaust seems to flow properly though both exaust pipes.
Old 02-08-2006, 07:47 AM
gmack221's Avatar
gmack221 gmack221 is offline
Re: engine problems
I'd start with a tune up, plugs, wires, fuel filter, bottle of injector cleaner in the tank.
Old 02-08-2006, 12:20 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: engine problems
one thing would be to change the air filter. Most dont change it often enough.
If you hav the stock air box, change it when you change the oil for best results
Its cheap for those filters, and you'll save $$$ on gas too.
1999 Grand Am SS 3.4 OHV
