Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 02-07-2006, 07:40 PM
crashedu182 crashedu182 is offline
Send a message via Yahoo to crashedu182
little noise
i've put a lot into this truck and am getting a lot of the noises it makes sorted out one i havent heard befor is a ping ping ping when i stomp on the gas,, sounds like might be comming from the trans,, just put in new oil pump rod bearings ,trans filter, u joints ,stearing box and pumpalong with a lot of other things if that helps
Old 02-08-2006, 09:31 AM
Truck Truck is offline
Re: little noise
Valve tap? I'm sure you change your oil regularly, but having problems under load is usually something Valve train related. IMO.
Old 02-08-2006, 08:57 PM
Re: little noise
no its more like a ping,,not a knock or tap sounds like its comming from the trans aera maybe ,, kinda loud sound,, and yea its had new oil pump connecting rod bearings more or less is rebuilt
