Old 02-07-2006, 04:24 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
How to fix that saggy door.
Hey guys we all know most old cars doors start to sag you cant see it but when you go to close it you have to find those tricks like pick up and push in or push in hard anywho my question is there a quick fix? the only one i know of is have a friend hold the door up and hammer a nail into the hinge but then it doesnt look very professional thanks for your time.
Old 02-07-2006, 04:47 PM
83T/A98Blazer 83T/A98Blazer is offline
Re: How to fix that saggy door.
I think replacing the hinge pins and bushings will take care of that problem. The only pain in the butt is getting the springs back in, but I bought a spring tool off Ebay and it helped a lot.
Old 02-13-2006, 03:49 AM
volkerc's Avatar
volkerc volkerc is offline
sagging doors on a low mileage car...?
Old 02-13-2006, 12:13 PM
TransFukinAm's Avatar
TransFukinAm TransFukinAm is offline
Send a message via AIM to TransFukinAm Send a message via MSN to TransFukinAm
Just because its got low mile wouldnt mean the hinges arnt shot. My car has 95,000 and they are shot... then again, so are alot of things on my car >.<
But yes, just replace the hinges if you want a "Professional Looking" fix.
Old 02-14-2006, 02:51 AM
volkerc's Avatar
95000 miles is not low miles. and the above mentioned car i referred to, supposedly has half of your miles...
Old 02-14-2006, 11:57 AM
79Bandit's Avatar
56k original body miles but was sitting for about 2 years before i got ahold and fixed her up.
Old 02-23-2006, 07:18 PM
well, i mean, 95 is kinda low for how old it is. and i went and checks and its only at 93,000-ish, but, most of the 82's ive seen have like 100,000 more miles than mine.
Old 02-23-2006, 10:47 PM
76ta's Avatar
76ta 76ta is offline
Send a message via MSN to 76ta
my car is currently in the shop gettin new sheetmetals and paint but i gave the guy the doorhinge kit from goodmark restoration parts and he says they did the trick
76ta
Old 02-25-2006, 08:58 AM
Formyla's Avatar
Formyla Formyla is offline
Get a 4' 2x4 board.
Place a small block of wood under the flat part of the door, (to protect the bottom edge of the door skin)
Put the end of the 2x4 on the door sill - the door open at 18" (out at the end of the door)
and lift the 2x4 to pry the door up.
Do it gently and check fit often so not to go too far.
Do this at your own risk!
00Formie
79TA
