Old 06-22-2002, 08:53 AM
88B18aHB 88B18aHB is offline
moving the battery
anybody moved there battery to the trunk i'm having trouble with getting my short air intake to sit right in the engine bay because i have a ls motor an the car is a 88 civic hb . the intake is rubbing the postive terimal almost on the battery i was thinking bout getting the Summit trunk mount battery kit .anybody got one or heard anything bout them
Old 06-22-2002, 10:30 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: moving the battery
I know someone with it relocated. Plus I am thinking about it myself.
But, for the problem at hand. You can take a piece of rubber hose, like the kind used on the end of your intake, and put it around the intake where your postive terminal is. That way it wont keep grounding out. Hope that makes some sense.
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
My Battery is in the back of my hatch, its a great and cheap mod. Also Dont buy the kit from summit, its wasted money. Go buy 4 guage wire from HomeDepot, about 14 feet, and a couple of feet of 2 guage wire for your ground. run the wire from your engine bay through one of the holes in your firewall, under your rug all the way to the back and your done, it's great because it evens out the weight distibution of the car.
Old 06-22-2002, 12:44 PM
kris's Avatar
You really should have some sort of fuse it between there somewhere. Something like the big fuses used in car audio.
Old 06-22-2002, 10:55 PM
Kb: I actually use circuit breakers instead one in engine bay, and one at battery, I tried fuses, but they would blow due to the power the starter needs.
Old 06-23-2002, 12:27 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yea fuses dont go that high, a starter usually requires about 2-300 amps of power to start, so aint no stereo fuse gonna do that
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-23-2002, 05:09 PM
kris's Avatar
Okay, well now I know that. But he didnt mention anything like that. Not everybody is smart enought to put something in there.
Old 06-23-2002, 06:35 PM
emil13si's Avatar
emil13si emil13si is offline
But what willyou do then, if you would like to have some subs(subwofer) in your trunk, I was thinking of that to to move battery but then I remembered that I need trunk space for music, so nothing won't come reality...
Oh yeah one advace use a strong wire( I mean for lot Ampers) to connect your previus wires, cause if it'll be to thin it will burn the plastick or rubber around the wire and cause the +(pluse) will came in touch with the ground and that is not good at all
I hope that you understand anything I wanned to say :flash:
Good luck
Powered by
CivicTypeKoshiR
Old 06-23-2002, 08:55 PM
Im sorry for not mentioning the safety devices, but in truth they arent necessary. I have been running my mr2 with the battery upfront(engine in rear) for years with out a breaker or fuse. Unless you have some sort of problem with your battery or connections there should be no problems.
Old 06-23-2002, 10:07 PM
kris's Avatar
There is no need for seat belts either, unless you get in a accident.
Old 06-23-2002, 10:14 PM
KB: if you say so, but the only difference between battery in front and back is 10 feet of cable. It's always better to be safe, but I doubt we are all following the speed limits either =).
Old 06-24-2002, 06:42 AM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
Hmmm... can't believe i'm the only one to point this out but he's driving a hatchback. I HIGHLY recommend going with a sealed battery such as an Optima Yellow top, non-sealed batteries can vent dangerous gases into the passenger compartment. The Optima can be mounted upside-down if you'd like but I wouldn't recommend it.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 06-24-2002, 07:04 AM
chzdhippt's Avatar
chzdhippt chzdhippt is offline
Send a message via ICQ to chzdhippt Send a message via AIM to chzdhippt
Plus they look cool if you have it all prettied up with your Amp rack and distribution block nearby.
ChzDhippt
Old 06-24-2002, 01:02 PM
thanks for telling me bout the gas. i knew that the battery would blow up if it was puntruced.but had not heard bout gas comming from the battery.plus looking over the kit i ordered seems to be crap now cause the bolts have to be welded an the kit has to be in a trunk to be legal at the track am im thinking that might be because of the gas.
Old 06-24-2002, 05:35 PM
Most race tracks require trunk-mounted batteries to be enclosed in a battery box. The difference between using your old battery and a new sealed battery is that with a regular battery you'd have to vent the box to the atmosphere to pass a tech inspection. With the Optima you'd just have to have it in a battery box with no need for a vent tube making life a lot easier and your hatch that much prettier.
1991 CRX SI (black)
'90 B18A1 swap
Custom exhaust
*2.25" piping
'95 GSR 15" wheels
Powerslot rotors
Metal Master pads
Skunk2 shift knob
