Old 02-07-2006, 03:23 PM
puff puff is offline
Unhappy 98 voyager no spark
I have a 1998 Plymouth Voyager 3.0 . It started and ran for about one min. then shutoff , now I have no Spark to plug's And no spark from coil. I've replaced coil with no effect.And I have a code 54 showing. Can someone tell me what code 54 mean's..
Old 02-07-2006, 10:10 PM
pada's Avatar
pada pada is offline
Re: 98 voyager no spark
hey Puff,
I'm no electronics expert, more of a nuts-n-bolts kinda guy, but it seems to me that since there's no output from the coil (thus no spark to the plugs) you should have the coil itself checked and/or replaced. It's probably the most logical and cheapest place to start ... ?
Paul (pada)
Old 02-20-2006, 02:23 PM
moparfanatek moparfanatek is offline
code 54 is no cam signal at the pcm; this means no cam shaft sensor reading is recieved, needs new cam sensor.
Old 02-24-2006, 01:14 PM
JCM007 JCM007 is offline
Thumbs up Re: 98 voyager no spark
Hi there i'm no car repair man, i just had the same thing happen to me
and i thought too, that the Iginition Coil was the problem thus no sparks.
Well after a week and pay check i call a friend and he mention to check
3 places A.-IGN Coil, B.-Timing Belt, and C-Distributor cap.
Answer was B. Timing belt
Man you should have seen the belt it look like someone set
rubber on a real thin thread of hot iron.
Which we fine out later the burnt smell was the rubber.
The cool thing is i have the same buddy who is going to repair the Van for
$375 with parts i supply and to me thats not bad at all.
Good luck!
