Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 02-07-2006, 02:40 PM
tmclaughlin tmclaughlin is offline
problem starting
i have a 97 bravada and it seems to have a problem starting. not in the morning or after it has been sitting for a while but only after i have been driving and then turn it off and then try to start it is sounds like it just isnt getting gas. help anyone?
Old 02-07-2006, 04:42 PM
glathrop glathrop is offline
Re: problem starting
Iam having the same problem with my 98 hope some has an anwser
Old 02-07-2006, 08:31 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
does the engine sound like it's cranking, or turning over normaly? a starter thats going bad will give you problems when hot because of the increased resitance when hot.
Old 02-07-2006, 08:48 PM
yes it sounds like it normaly does when it tries to start
Old 02-07-2006, 10:33 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
You might try checking the fuel pressure, I read it has to be on spec before it'll start...62psi I think.
Old 02-08-2006, 06:27 PM
ericn1300's Avatar
AF Premium User
yeah, they're pretty sensetive to fuel pressure. if the pressure is good and you have spark you might want to check the crank postion sensor. here's a link how to:
http://www.autozone.com/servlet/UiBr...3d8018b8a6.jsp
