Go Back   Automotive Forums Car Chat > Buick > Century
Old 02-07-2006, 07:47 AM
rum runner rum runner is offline
Low compression 3.3L V-6
1992 120,000 miles 3.3L
I have low compression in 2 cylinders. Is this common on these engines? Would the head gasket be the first thing to look at? Do the ring packs get sludged up on these engines? Valve problems?? Engine has had regular up-keep.
Thanks
Old 02-07-2006, 07:57 AM
maxwedge maxwedge is offline
A990 racer
Re: Low compression 3.3L V-6
What are the running symptoms, loosing coolant rough engine, overheating?
Old 02-07-2006, 09:38 AM
Standing in the front of the motor the first two cylinders on the left side have low readings on compression, in the 50 psi range. All others read 100+.
The engine starts well, runs well except under load, up speed in high gear. Then it seems to miss. It doesn’t seem to loose coolant or overheat. It does have a small miss or putt sound while idling.
Thanks for the reply,
rr
Old 02-07-2006, 10:42 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Check my response in the Grand Am forum but this sounds like a bad head gasket. Of course other problems may exist.
Old 02-07-2006, 07:20 PM
stoned_pimp420 stoned_pimp420 is offline
Send a message via Yahoo to stoned_pimp420
I haven't had a chance to check it out on my new buick, but it sounds like you are describing the EXACT same sound that mine makesat idle and under load, so I think that if one of us figures out the problem then we'll have the answer to both our problems!!!!
I'm back after a long mental evaluation and heavy medication!
If you can't be a good example, you can always be a horrible warning!
Old 02-09-2006, 12:44 AM
INDEED it is, I checked the compression on my 3300 and it has a ack of com. on the front/left two cylinders, so if I can figure out what's wrong with mine I'll post it and you may be able to fix yours!!!!
Old 02-09-2006, 05:23 AM
Originally Posted by stoned_pimp420
INDEED it is, I checked the compression on my 3300 and it has a lack of compression on the front/left two cylinders, so if I can figure out what's wrong with mine I'll post it and you may be able to fix yours!!!!
So yours is the same two cylinders? Hummm, maybe it's a design flaw. The funny thing is this car is old but has good power, doesn't use any oil or overheat.
Old 02-09-2006, 05:24 AM
Old 02-09-2006, 09:55 AM
Yep the same thing here, my old BLUick (R.I.P.)made the exact same sound except it was far worse and was way underpowered, this century makes a little less noise than the bluick did and has a TON more power than the bluick did, near the end my bluick started sounding almost like a diesel or something if I drove uphills at low RPM the bluick had (i think) 192,xxx when I flipped it and my new century has 197,xxx on it so I don't know I've got a few things I'm wanting to check between the two anyways before the bluick goes to the crusher.
