Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 02-07-2006, 07:13 AM
Dadaman Dadaman is offline
Unhappy 93 Bravada - Spider???
The dealer tried to charge me over $1000 for parts and installation of a "spider kit". I'm doing it myself but.... No matter where I look I can't find a "spider kit" and or any related parts or info on how to.
Help
Dadaman confused
Old 02-07-2006, 08:53 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 93 Bravada - Spider???
The Spider is the little CPI injector with 6 little injector lines and poppets at the end of those lines....looks like a spider if you imagine hard enough.
There are 2 larger lines that connect to it also, they're the fuel supply and fuel return to the fuel tank lines.
If you take the top off the manifold, you'll find a puddle of gasoline. A puddle on the driver side is cracked fuel supply & return lines...the CPI is OK, buy a nut kit(which is what they call the fuel lines???)!
A puddle on the passenger side means the CPI regulator is bad but another regulator is available.
http://www.lindertech.com/reconinj.htm
Old 02-12-2006, 01:31 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
The regulator is available at any autoparts store now in the HELP! section. If they don't have it in stock, usually only takes a day to get it.
This how-to will focus on changing out of the regulator only though it can be applied to swapping the entire CPI... Typically it's the regulator that goes bad, but because of how detrimental this part is to running, I wouldn't advocate buying this part online. Since the regulator is now available at most autoparts stores from Help! Part #55162, it's much easier to swap out a defective unit.
Tools needed.
10mm deepwell socket (Must be a deep well)
8mm socket
T30 Torx Bit
Paper towels
Either a complete CPI
or
Help! Part # 55162 (the reugulator) Includes the needed Torx security bit for retainer removal. (About $40.00 at Autozone, Pepboys, or Advance autoparts)
New plenum gasket.
First remove your intake air feed and disconnect the air temp sensor. Then remove the 2 bolts holding the VORTECH cover on. (The bolts holding this on are T30)
Here you can see where I disconnected the air intake temp sensor and started loosening the cover bolts
Next Disconnect the linkage from the throttle butterfly and remove the 2 8mm bolts holding the top of the cable bracket to the upper intake.
Disconnect all sensor connectors and move them out of the way.
Using your 10mm deepwell socket, Starting with the bolt holding the bracket, work your way around the plenum. There are 9 bolts to be removed. As you get to the bracket holding 1st the coil bracket and then on the opposite side the fuel recovery module, you 1st need to remove the 2 top nuts then set the bracket out of the way then remove the bolt(s) holding the plenum down.
As you remove these bolts (and nuts) Lay them out in order. Several of the bolts are different sizes, so if you lay them out in order, you can simply put them in reverse.
Disconnect the small vac hose from the back of the plenum, then the larger hose at the brake booster.
Lift the plenum straight up.
Here we see that the passenger side of the upper plenum is very washed (note the gold covering)
Here we have the lower intake. Note that the passenger side is almost clean while the driver's side with the nutkit is nice and dirty.
Next I stuffed all the intake ports with paper towels. Why? Becuase you DO NOT want to take the chance of dropping something down there. (Last time I did I destroyed a motor, )
Here is a shot of the regulator SImply remove the 2 screws holding the retaining ring on. (Help! was thoughtful enough to provide the security Torx bit needed to do this)
A shot of the retainer ring removed
A shot of the new regulator (left) and the old one (right)
Here is the new regulator on the CPI (pre retainer installation)
Now make sure that the mating area is completely clear of any old gasket material. If needed, use a razor blade to scrape the mating surface. For some areas if too difficult, use sand paper.
A final shot prior to putting it back together w/ the new plenum gasket
Simply reinstall everything in reverse
Starting at the bolt at the bracket, torque in circular patter to 8 ft pounds
Wala your're done!
Note: Prior to putting it back together, it's a good time to pull the distributor cap and check the condition of your cap and rotor. The reason I mention this is because of how difficult it is to get to that front screw.
Old 02-12-2006, 07:59 PM
AF - Advisor
Rlith, you rule
Great pics and explaination, thanks for the most cool info!
Old 02-12-2006, 08:02 PM
rlith's Avatar
Originally Posted by Chris Stewart
Rlith, you rule
No prob. Remember, anything that applies to the blazer/jimmy/sonoma/s10 also applies to the bravadas (cept the AWD which is basically like 4wd with a limited slip front diff and a locking transfer case)
Old 02-17-2006, 05:32 PM
AF - Advisor
There's the fuel line kit (nut kit) available too...#55163
