Old 02-07-2006, 07:16 AM
J.Cutta's Avatar
J.Cutta J.Cutta is offline
Trans Problem
I believe the tranny I have is still in good working order but I'm not sure what exactly the problem is that i'm having it has been doin this for a year now I guess it is slipping but in only in low gears. The problem is about around 30 mphs when u hold the pedal steady the sound coming from the exhaust becomes very deep and rpms drop slightly and it will stay this way until you apply more pressure to the pedal. The transmission I guess is rebuild I seen a year ago it was fixed because it would not go into reverse.
http://www.cardomain.com/ride/631458
_______________
92 Camaro V8 TBI 305 with Dynomax 3" Catback Exhaust, ASCD Iroc Turbo Hood, Goodyear Triple Tread Tires, K&N Open Element, Cat Delete, WonderBar Steering Brace, 160 Thermostat
Old 02-07-2006, 07:21 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Trans Problem
sounds to me like its just going into overdrive or upshifting... doesn't really seem like anything is wrong...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 02-07-2006, 12:35 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Trans Problem
ya they upshift to a lower rpm so you save gas, it is normal, my dads 94 camaro did that.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-07-2006, 06:21 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Re: Trans Problem
Just the trans trying to save energy.
Old 02-08-2006, 10:54 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Trans Problem
throttle valve cable could be out of adjustment.
Old 02-08-2006, 01:44 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: Trans Problem
Like everyone else said its normal especially for older trans to shift up early. My 89 drove me nuts with that. Adjusting the tv cable helps a little but dont go nuts with it or you could mess up your transmission.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 02-08-2006, 06:31 PM
Re: Trans Problem
One year after I got my tranny rebuilt, I had to have it serviced (required if you dont want to void the warranty) and I remember thinking that it was shifting wierd, but after the service(trans fluid flush and filter change) it seemed to shift completely differently. If your trans is under warranty, you may want to double check your paper work to make shure you dont need to take it in for a service, or you may end up voiding your warranty...but wether or not you have to get it serviced, you should have it serviced once a year or every 12k miles. Saves a lot of money in the long run, and you can do it your self if the warranty doesnt require you to have it done at the shop.
Also, if it is under warranty, you should take it back to the shop and take a ride with one of the techs and show him whats bothering you, just to be on the safe side.
Old 02-09-2006, 01:39 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Trans Problem
could be the torque converter locking/unlocking...
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 02-09-2006, 02:58 AM
J.Cutta's Avatar
Re: Trans Problem
what is the normal cost for a rebuild of a transmission. I'm hearing alot of crazy prices 1750....Do you guys think a trans cooler would help the problem it can't be normal
_______________
Old 02-09-2006, 03:08 AM
J.Cutta's Avatar
Re: Trans Problem
I remeber went I first got it it did not do this. But one day I was going about 20 or so and just floored the pedal the car choked like it was about to cut-off but kept running and it has done this ever since.
The reason I ask this is because I want to put a posi-unit and some 3.42 gears on it but with the transmission acting funny I will just burn it out quicker right?
_______________
Old 02-09-2006, 10:07 AM
wrightz28's Avatar
Re: Trans Problem
What does the fluid look like?
Old 02-09-2006, 12:49 PM
97cavalier's Avatar
Re: Trans Problem
it will stay in the low gear unless you let off the gas and hit it to the floor then, otherwise it will speed up but it will be bogged.
Old 02-09-2006, 01:44 PM
J.Cutta's Avatar
Re: Trans Problem
I went to the trans shop today. The guy said the trans is in good condition but it does shift soft thru the first and second gear. He said the throttle valve needs to be updated and a corvette servo install would help it shift like a camaro should. 400 dollars what do you guys think...
_______________
Old 02-09-2006, 02:08 PM
Re: Trans Problem
throttle valve update??
Old 02-09-2006, 03:00 PM
wrightz28's Avatar
Re: Trans Problem
i think that's a package deal with a muffler bearing?
The vetter servo would help, but do you already have a shift improver kit installed?
