Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-06-2006, 10:52 PM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
retorking head bolts,
I am getting a litting bit of Oil in my my 4# cylinder, Its kinda wierd becuase all the other cylinder's are fine. I am getting oil on my spark plug. Anyways my question is Should I ""retork"" my head bolts, I seen people retighten there head bolts on civics by giving the head bolts a quarter turn but im not sure if i can do that on a dsm,
please help on this becuase im not trying to F*$# my motor.
Also the engine is a 4g63 DOHC, And then engine got 154,000miles on it.
thanks
P.s. I know I spelled "tork" wrong.
Old 02-07-2006, 12:22 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: retorking head bolts,
I'd say that probably wont help, unless the bolts aren't torqued down right in the first place. You probably need a new head gasket, unfortunetely thats a fairly big ordeal, but if your timing belt has not been replaced yet it might not be a bad idea to go for it.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 02-10-2006, 01:13 AM
joemathews's Avatar
joemathews joemathews is offline
If you know you spelled "tork" wrong then why the $&*@ would you spell it that way?
Your head bolts are fine. Sounds like you have blown valve stem seals in cylinder #4. Looks like it's time to pull the head and examine the HG. You'll be replacing that anyway, so you might as well fix your valve stem seals as well.
Search DSMtuners for "valve stem seals" or "Miller tool" for more info on the procedure.
1996 Eagle Talon
