Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 02-06-2006, 10:13 PM
CODITHsaves CODITHsaves is offline
Unhappy 2000 eclipse sound sys drivin me nuts
2000 eclipse GT. i got the 7 speaker 210watt infinity sound sys in there
i have the main wiring harness for a new head unit and appearently all it offers me is the power for the head unit so i see that this one bus-style cable runs to the amp so i guess i need to bypass this amp?
first off, where is the dam amp even at in the car
second, is the amp and cross-overs for the component speakers the same unit so i have to get new crossovers for the shit too or what?
let me know anything else you feel is appropriate for me to know for this project please
your help is appreciated
Old 02-06-2006, 11:54 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: 2000 eclipse sound sys drivin me nuts
http://www.club3g.com/forum/forumdisplay.php?f=29
that might answer some of your questions, as far as audio goes, cficare and rodbls know some thangs
Don't act like you don't love it.
503/2000
Old 02-07-2006, 12:33 AM
Post Re: 2000 eclipse sound sys drivin me nuts
so i did some searching to find some answers for my own questions that i wish to share
http://www.discountcarstereo.com/detail.aspx?ID=434
that is an adapter that will work on either side of the signal bus cable going from the factory head unit to the factory amp so you can use it to use a new head unit with the existing amp/speakers/wiring or you can use the factory head unit with a new amp and any wiring you want from there
and ya the factory amp's under the passenger seat
i still dont know if this "MR400692" factory Infinity amp unit also contains the crossovers for the conponent speakers or not so if anyone knows, let me know
Old 02-07-2006, 12:42 AM
Sleepr awd's Avatar
umm... maybe check the link i gave you...? they've got a ton of info
503/2000
Old 02-07-2006, 03:37 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
You are asking about crossovers for component speakers correct? Now, when you are talking about components are you refering to the stock speakers, or aftermarket components you put in. Stock speakers are NOT components (far from it). The stock amp is probably set for safe shitty speaker settings (no boosted db's or high or low frequencies). I doubt there is anything you can tune with it because it's stock. Since you put in a new head unit you may as well put in new speakers. Anf if you are putting in new speakers why would you want to run the stock amp...you are just holding yourself back and defeating the purpose of upgrading speakers. Better speakers need more power, and 210watt aint gonna cut it. If you have specific questions PM me, Ill let you know what I think.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
