Old 02-06-2006, 05:13 PM
lionelkirk2004 lionelkirk2004 is offline
Send a message via Yahoo to lionelkirk2004
Intake Gasket Question
If I drain the oil out of the car could I drive it to where it needs to be fixed? As long as it isn't to far?
Old 02-06-2006, 07:29 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Intake Gasket Question
NO! If you run the engine without oil you will destroy the engine. Drain the oil and put in some cheap oil. You will need to change it anyway so don't spend a lot on the oil until after the car is repaired, also make sure you change the filter at the same time.
Old 02-08-2006, 10:24 AM
so if i drain the oil and then put some cheap oil back in I can drive it where it needs to be fixed? How much oil should I put in?
Old 02-08-2006, 11:02 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
What engine?
How far are you going to drive it?
How bad is it leaking?
If it is leaking coolant very fast it could over heat to.
And put it all of the coolant back i the oil pan back.
It would be a lot safer to call a tow truck.
A tow truck may be a 100 dollars and may be covered under insurance.
But a new engine may be 2-3 grand.
Think about it. MT
MT
Old 02-08-2006, 01:26 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
think you should put the amount of oil the engine calls for...... thats just my
1999 Grand Am SS 3.4 OHV
Old 02-08-2006, 02:38 PM
Pontiac Guy
Put the correct amount of oil into the vehicle just like you were going to do an oil change. Then drive it directly to the repair shop. Driving it further can result in bearing damage.
