Low vacuum and flooding
Greetings,
Here is what is happening. At cold start I can not press the accelerator until the car warms up or the car dies by flooding out. After the car warms up and I can drive it - it lacks power - its rare that it gets up to 70mph. Here is what I know... My spark plugs are clean and my wires, cap and rotor have been recently replaced. I would think with it flooding out that the plugs would be black with carbon... but they are not. Vacuum= 15 +/- 1 with a bounce (This seems low) Fuel pressure with Key on, engine off = 28 Fuel pressure engine running = 21 Compression test: All cylinders between 140-150 Checked resistance of both ECT and Air temp sensor and they read in the proper amouont of ohms for the temperature and change quickly when warmed or cooled Cat converter has been removed changed nothing. Timing has been checked and set per the label under the hood. A few odd questions... with low vacuum shouldn't the map sensor be telling the ECU to lean fuel? Can I still get good compression readings like those I posted if I have a cam or valve issue? |
Re: Low vacuum and flooding
Beowolfe
I would think low vacuum would indicate a load so it would actually send more fuel but since its in a closed loop with the feedback of the O2 I don't know if that would actually happen.What signs do you have that its too rich of a mixture when it dies,I'm certainly no expert just picking your brain,I'm sure someone will jump in with the right answer eventually Unbe |
Mouse
You must be referring to ignition not cam timing. Unbe |
Lol, hmmmmm I think I am going to go nuts.
I pulled off the timing belt cover and the cam and crank seemed lined up perfectly so I reassembled and checked my timing. My timing was set at 10, so I moved it back down to the recommened 5 - car ran like crap... so for fun I advanced the timing as much as i could by twisting the distributor. The car runs much better with it pushed all the way to the max. At this point I want to kick myself. When I pulled it apart to check if the cam and crank where lined up I did not pull the crank gear bolt out and inspect the key way :/. I am starting to get the feeling that the crank gear may have rotated on the crankshaft. This has happened to me before on the last engine I had in my metro. It was an oil burner and had crappy compression so when the keyway got chewed up I just replaced the engine. Has any one here successfully repair a crankshaft keyway? If so I could use some tips. |
If this is a JDM motor I would have to wonder if there are some that are different, requiring the timing to be advanced more than normal metift (or is it switro) engine. I fought with mine for a couple of weeks, no power, ran hot, no gas mileage, etc, until I started playing with the timing. Once I advanced the timing the motor started behaving normally. I still have a little adjustment room left and my mileage is not quite what it should be, but since it is a guessing game at this time and it's not knocking I've left well enough alone. I wonder if the crank and/ or cam pulleys are different, I put the metro ones on since the timing belt looked pretty worn out and I had a brand new metro timing belt. Let us know what you find, I will definately be watching.
Jon
Check out the post about 91 METRO CRANKS BUT WONT START its still on the first page it was only a few days ago.Good luck. Unbe |
Ah HA!
*me holds up a bent up crank key way* I replaced the keyway and cleaned and buffed up the crank shaft and pully. I needed to fill in the gaps that got worn out with some JB weld. Reassembled, My vacuum is now hitting 22 and my power (well as much power as a metro can get) has returned! |
Jon
