Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-06-2006, 03:27 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
Accident Pictures
Just got the car back from the shop. Everything mechanically wrong was fixed. Anyway, here's the cosmetic aftermath:
Car from drivers side:
Fender & Hood:
Back of the car (note: the left side was already damaged.):
Ugg. It got the fiberglass & the taillight :
Damaged rim:
The paint looks good even when it's really really dirty :
Custom fiberglass & bondo mount for my HU:
Well, that's about it. I guess the damage could have been worse. I'm still mad it took out my rim though
BTW, anyone have a brougham emblem for the trunk I could buy on the cheap?
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 02-06-2006, 10:17 PM
88capriceclassic 88capriceclassic is offline
Re: Accident Pictures
yea that corner/taillight pic looks pretty bad.my right corner fiberglass is kinda busted up because someone hit it with a shopping cart a while ago but its not bad but very noticeable from up close. if i wanted to fix that, what would i hav eto do?get a whole naw back piece?
Old 02-06-2006, 10:50 PM
Cyrix_2k's Avatar
I think it can be fixed with just bondo. Bondo DOES stick to fiberglass... that's how I made the black piece my headunit is mounted in. If not, you can glass the rough stuff and finish it with bondo. I'm going to be working on mine in a while (probably a few weeks). I'll let you know how it turns out and I'll try to take pics as I work.
Oh yeah, make SURE you wear gloves when working with fiberglass. It itches like crazy. Trust me, I found out the hard way.
Old 02-06-2006, 11:24 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I love living near a cheap junkyard (Ecology). Entire back piece with taillight assemblies - $40. I backed into a Dodge Ram a few years back in mine and did damage to the fiberglass not unlike your pic above. $40 later and you can't tell it was ever touched.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-07-2006, 02:08 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Have you checked out any junkyards yet? The fender and hood should be an easy fix when you get the parts. I would just bondo the fiberglass like they said.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 02-07-2006, 03:30 PM
Cyrix_2k's Avatar
Yep, I can get a fender for $40 & a rear bumper for $75. Those prices are for the part pulled; it's cheaper if I pull it. I haven't located a hood yet.
Also, there's a driverside tailight in the mail
Old 02-08-2006, 02:18 PM
directory's Avatar
directory directory is offline
that's fun. do the parts match color wise?
what was all of this damage from?
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 02-08-2006, 02:20 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
one word, OUCH!!
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 02-08-2006, 03:12 PM
Cyrix_2k's Avatar
Parts don't match color wise, but I'm going to either paint them myself or have them painted to match.
The damage is from this http://www.automotiveforums.com/vbul...d.php?t=512555
Also, anyone want to give a guest-imate of value on the car as it is right now? It has new shocks, exhuast (flowmaster 40s series clone), new tires (2003, but only about 3k miles) on wire wheels (not the ones in the picture), new idler arm, new tie-rod ends, new alternator, new A/C as of 2003, new serpentine belt (and I also have one that only had a few hundred miles on it), new brake pads & rotors as of ~5000 miles ago (2003), new radiator as of 2003, new plugs, wires, & rotor as of 2003, and the CD player pictured. It has 134000 miles on it. Obviously, I'm not hiding anything I had my mechanic go through everything after the accident to make sure it's safe hence the new parts. The reason I'm considering selling it is because I want a smaller car, but that's really just a thougt. I also want a manual transmission.
Thanks
Old 02-09-2006, 03:14 PM
Cyrix_2k's Avatar
Update: I just got a gallon of bondo, extra hardener (they never include enough), and some paint. I already have sandpaper ranging from 80 to 2000 grit, rubbing compound, and all the other stuff I need. Hopefully I'll get to work on it over the weekend. I just want to get the trunk & fiberglass fixed.
88Caprice, I'll let you know how the fiberglass repair turns out
Old 02-14-2006, 03:23 PM
Cyrix_2k's Avatar
Should be getting the bumper, fender, and tailight soon
Old 02-24-2006, 06:12 PM
Cyrix_2k's Avatar
The tailight's here and the bumper & fender are at the mechanic's. The fender has a small ding in the top (not bad at all) so my mechanic talked to a body guy & is getting it fixed FREE! The fender also has an antenna which I needed and all the chrome edging. The bumper is pretty good, but needs a new black rubber strip thing. The car should look awesome by the time I'm done
