95 mystake idles then dies
had tranny rebuilt then had to replace timing belt and pulleys not cheap 3 pulleys and belt now will run idle then motor will dieafter 40 minutes at idle then wont restart till it cools off ran a eec4 scan got codes 17,21,23,27,68 any help ????? was told it could crankshaft position sensor
Re: 95 mystake idles then dies
it sounds liek what my car was doing, it was fine when it was cold but once it warmed up it would stall, my timing was off 1 notch.
-Josh- 96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel 98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp. 01' Chevy Blazer, DD. |
Code 17 Idle RPM Low With ISC Retracted (1.9L & 2.5L CFI) Code 21 Engine Coolant Temperature (ECT) Sensor Out Of Self Test Range Code 23 Throttle Position Sensor Out Of Self Test Range Code 27 Vehicle Speed Sensor (2.3L Turbo) Code 68 Idle Tracking Switch Closed (1.9L, 2.3L, 2.5L & 3.8L CFI)
Jack of all trades...Master of none! Could someone please fix my Instant Email Notification? Please get back to us with your fix! Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
