Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 02-06-2006, 02:07 PM
cinders cinders is offline
Door makes clicking sound when opened
I have a 2000 Sebring Conv. Recently it has been making a clicking sound when I open the door. Does anyone have an idea what this means. I don't want to just let it go but also don't want given any bs when I take it to the dealer.
many thanks
C
Old 02-07-2006, 03:52 PM
HKS22 HKS22 is offline
Send a message via AIM to HKS22
Re: Door makes clicking sound when opened
many thanks
C
Ok...did you look at the front quater panels? The door may be hitting then going behind the panel. That is what might be causing the clicking noise.
Here is a pic...I hope you can correct the problem with your car.
Old 02-08-2006, 09:48 AM
tayl0124 tayl0124 is offline
it is probably what they call the door checks. It is a common problem with these cars. It really isn't much of a problem unless they completly brake off. but it is annoying. Mine have been broken for 3 years already.
Old 02-09-2006, 10:19 PM
96cbring 96cbring is offline
mine makes the same dame noise and u hate it with a passion i have a 96 jxi how can i fix that shyt its not the hiting the fender and i have put wd40 everywere still the same shyt
Old 02-10-2006, 05:17 PM
you have to replace the door checks. check out this site. A great sight for sebring owners.
http://www.sebringclub.net/board/portal.php
here is how to replace the checks.
http://www.sebringclub.net/gallery/doorcheck
Hope this helps.
Old 02-23-2006, 04:59 PM
jerhenz jerhenz is offline
Mine does the same thing every year or two. It is because the convertable doesn't support the doors as well as a hard top, and the door droops enough to make intermittent contact with the door sensors. It takes 10 minutes to tighten it up while holding the door in place.
