Old 02-06-2006, 02:02 PM
seldomo19's Avatar
seldomo19 seldomo19 is offline
Will Not Start
My moms 94' buick Park Avenue will not start.
It makes the noise like it will but it doesn't
It has a new battery and everything.....what could it be?
PLEASE>>>>>>>I NEED HELP.
Toting 2 Kids around in Sunny South Florida in my 2006 Dodge Caravan
Old 02-06-2006, 08:46 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Will Not Start
Some basic test needed first, do you have spark and fuel?
Old 02-07-2006, 05:52 PM
seldomo19's Avatar
Re: Will Not Start
Yes, it is getting fuel, we will check the spark next.
What is the best way to check the spark?
It has a new crank shaft sensor, new harmonic balancer.
Old 02-07-2006, 08:38 PM
HotZ28's Avatar
AF Moderator Elite
Re: Will Not Start
If you don't have the usual spark tester, you can pull a plug wire and insert a spare sparkplug in the wire boot. Touch the plug to ground while someone turn the engine over. You should have a good blue spark on the plug, just like it was in the combustion chamber. You can aslo use a screwdriver inserted into the wire boot to see if you have spark to ground. It should fire to ground about 1/4 to 1/2 in. The spark needs to be blue in color in order to fire the engine. If you have a timing light, you can use that just like you are checking the timing. If you have light, you have fire. The only problem with this method is, you can not see how hot the flame is.
Old 02-08-2006, 08:09 PM
seldomo19's Avatar
Re: Will Not Start
My dad had checked the car for the spark...THERE WAS NONE!!!!
Where do we go from there......
If you need my email it is [email protected]
Old 02-08-2006, 08:55 PM
HotZ28's Avatar
AF Moderator Elite
Re: Will Not Start
It would be nice if you had a scanner to check engine RPM while trying to start it. If you don't get a RPM reading, that would tell you if it is the crank sensor. If you can't do that, you may have to change parts to find the problem. Usually, it is either the crank sensor or the ICM (ignition control module) located under the coil packs. I assume from your original post, that the engine is turning over when you attempt to start it.
Old 02-08-2006, 09:29 PM
seldomo19's Avatar
Re: Will Not Start
Harmonic balancer has been changed
Crank shaft sensor has been changed
It is getting fuel
Car turns over
No fuel
What is the cost for an ICM?
What is the procedures to change them out?
Old 02-09-2006, 10:58 AM
HotZ28's Avatar
AF Moderator Elite
Re: Will Not Start
Price of a new ICM can range from $125-$200 depending on where you get it. I would go to a bone yard and pick up a good used one for 50 bucks or less. It is located under the coils. You need to remove the small bolts (2) on each coil and set all the coils aside. The ICM has a wiring connector with one small screw in the center. Remove the screw and pull off the connector. The ICM will just lift out. You could take it to AutoZone for testing, before you purchase another one.
Old 02-10-2006, 11:42 AM
seldomo19's Avatar
Re: Will Not Start
What else could I tell my dad to get my moms car back on the road......
Old 02-10-2006, 12:57 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Will Not Start
I'd remove the coils and ignition module, take them to autozone and have them tested there. If they test bad, then you found your no-spark problem. It only takes a few minutes to remove from the car and the test is free, so you can't go wrong!
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
