Old 02-06-2006, 12:44 PM
cc2001 cc2001 is offline
Wind noise 2002 cavalier LS
Hello
I have bad wind noise in my 2002 cavalier LS, I have checked all trim and weatherstripping, all looks new. It is worst on the drivers side right at the top corner of the window, I can pull in on it from the inside while driving and it dies down. I can open the back door and look at the top corner of the front door and it looks like it is not even touching the rubber. Car has never been wrecked.
Please Help.
Old 02-06-2006, 03:17 PM
|WYG|SS |WYG|SS is offline
Re: Wind noise 2002 cavalier LS
Originally Posted by cc2001
Hello
Please Help.
well the thing is flat on my car around drvers door too and i can hear the wind. i heard on those cars shows on sike tv that u can take some rtv or something and just keep building it up i guess till the rubber touches the door.
Old 02-06-2006, 04:40 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
probably just normal.. cavaliers are noisey
Old 02-14-2006, 07:07 PM
03CavyMan 03CavyMan is offline
Send a message via AIM to 03CavyMan Send a message via MSN to 03CavyMan
It sounds like the window applique to me, you know the black thing on the outside of your door that goes from the bottom of the window to the top of the door? Roll down the window and remove the weather stripping along where the window sits at the back of the door. There will be 3 screws holding the applique on. sometimes they'll crack right where the screw holds it to the door. That will cause a wind noise. You'll have to replace it if the applique. It may also be loose, try tightning the screws if it is not cracked, but not *too* tight. They can be a bit of a pain in the ass to replace, just be sure not to lose the bottom screw down in the door panel... trust me, been there done that..
2000 Chevrolet Silverado Regular Cab Short Box
4.3L Vortec - 5 speed
Ion Alloy 16x8" chrome wheels
Magnaflow Catback Exhaust
K&N Intake, Throttle Body Spacer
GM Automotive Technician
Previously - 2003 Chevrolet Cavalier
Old 03-11-2007, 02:43 PM
shadbelly shadbelly is offline
I had the same problem. THe dealer fixed, no charge. said it was a customer service thing. THe doors can get slightly twisted. THey fixed it, sprayed door rubbers with silicon spray. works great since.
Old 03-12-2007, 12:04 AM
yhandor's Avatar
yhandor yhandor is offline
Send a message via MSN to yhandor
just fixed this problem today actually.....when you open the door, look where to clip is that the door latches onto, there is 2 bolts on it, loosen them, and push the latch towards your interior more, and tighten...should take care of it.....I had god awful wind noise, I mean I crank my music and still heard it over the music....no, completely silent, what it does is whe nyou move it back more, makes the door seal more because the latch is back which holds the door closer to the interior.....let me know if that works!
