Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-06-2006, 12:33 PM
racook2 racook2 is offline
Flashing O/D Off Light means what???
98 model, the "O/D off" light is flashing and the car doesn't want to go into overdrive... Pressing the button on the shifter doesn't affect it... I'm sure this is something electrical, and of course I don't have the owners manual to look this one up... any ideas?
Old 02-06-2006, 05:25 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Flashing O/D Off Light means what???
does it have a hard shift from 1-2 and does it have high shift points (6,500rpm-6,800) ?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 02-07-2006, 09:11 AM
yes, or else i have to let off the accelerator then wait for the shift....
Old 02-07-2006, 10:47 AM
pre98zetec's Avatar
Sound's like the TSS (Turbine Speed Sensor) to me.
Make a post on www.contour.org and ask around, they know more than I do.
-Josh-
Old 02-16-2006, 08:28 AM
C. Cleve C. Cleve is offline
Hi, RE your contour with high shift points and flashing o/d lamp, Possible TSS, More likely the VSS, Vehicle speed sensor, There is a ford TSB on it, This can happen without emiting a code, Good luck, they are not real easy to change...Clay..
Old 03-08-2006, 12:03 AM
glasser3 glasser3 is offline
Send a message via AIM to glasser3 Send a message via MSN to glasser3 Send a message via Yahoo to glasser3
ok i dont know anything about your problem but this brought up a problem of my own ... does anyone know how to get the overdrive working some back yard mechanic unhooked it in my 1998 contour sport before i bought it
Old 03-08-2006, 09:06 AM
Hi, glasser3, Take a good look at the above posts, They should point you in the right direction.....See Ya, Clay...
Old 03-08-2006, 09:07 AM
pre98zetec's Avatar
take your shifter handle off, take the cover off the shifter stick. There should be two wires (green and black, or green and white). Wire up a SPST switch to it and mount it somewheres convienent.
-Josh-
Old 03-08-2006, 05:23 PM
thanks for the help ill try that this weekend ill keep yall updated as to what if any other suprises i find while working on it
Old 06-04-2007, 07:10 PM
mitchcity mitchcity is offline
did you ever get it fix i have the same Problem now on my 1998 ford contour gl
