Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 02-06-2006, 11:42 AM
jkota jkota is offline
01 Trooper Check Engine Light
In an attempt to recover a couple extra MPG, I changed my spark plugs (with Bosch Plugs). I forgot to attach the last wire and went for a test drive. I immediately realized what I had done and reconnected the wire. Shortly thereafter my check engine light came on. It is solid while idling and flashes while driving. I'm assuming this is what caused the light. I am at almost exactly 75k miles. The light does come on as a scheduled maintenance reminder (but doesn't flash).
This is also the first time I havre changed plugs in this type of ignition sysyem (with the individual coils on top of each plug). I never felt any sort of connection between the new plugs and the "wire tube things" (techie jargon)... The vehicle seems to be running fine.
Can anyone tell me if this may go off by itself or do I need to have it reset? If so, how long is the cycle until it goes out?
Thanks
Old 02-06-2006, 12:11 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 01 Trooper Check Engine Light
First I would reset the ECU by disconecting the battery for 15-30 mins.
if that doesn't work it probably that Isuzu don't like bosch plugs:
"It has been suggested that bosch platinum plugs commonly cause the CEL to come on in +98 Isuzu's."
http://isuzufaq.ibctech.ca/#faq15
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-06-2006, 12:18 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
I'm sure someone else will chime in (... Joel or Ryan ) but it sounds as if you have the classic flashing CEL due to installing the wrong plugs in an Isuzu that has the Ion Sensing ignition system (2001+).
2000 VW New Beetle TDI
2007 Honda CR-V
Old 02-06-2006, 04:59 PM
rodeo02 rodeo02 is offline
Yes, scrap the bosch plugs. Too bad you didn't catch this forum first! The 2000+ are very particular due to the ion sensing ignition system. Replace with denso (sparkplugs.com), the champions specified in the manual or word has it, regular ol' NGK's work as well. The CEL does not come on at regular intervals to prompt for maintenance. Make sure you keep coil #6 only at #6. It's the coil nearest the brake booster. It's a shorty coil due to space constraints.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
