Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 02-06-2006, 11:12 AM
jase386 jase386 is offline
Send a message via AIM to jase386
92 Deville Trans
went to look at a 92 deville for sale in our area that was cheap. it has a transmission problem ive never seen before.
When you crank the car, the engine runs, and pumps the Transfluid out of the transmission onto the ground.
with the car running, a stream about the size of what the dish detergent bottle allows, runs onto the ground. from the front of the car, i can see the transmission pan, and the stream is coming from higher up than the gasket. it is coming from the front of the transmission, about 4 inches to the right of the left edge of the transmission pan.
anyone have any ideas on what this might be? I want a 92-93 deville, and look at them all the time, but have never heard of one doing this.
Old 02-06-2006, 12:44 PM
maxwedge maxwedge is offline
A990 racer
Re: 92 Deville Trans
Could be a bad convertor or pump seal, broken cooler line, you need to get a closer look at it, if not the line, the trans comes out.
Old 02-11-2006, 08:35 PM
creeker creeker is offline
I think the key word in your question is "running" , you should be running as far away as you can get from the car, if it was an easy fix the owner would
probably keep it.
Old 02-11-2006, 11:53 PM
plathegame plathegame is offline
the pump is probably bad.. common gm problem.. instead of the pump pumping the fluid into the trans it pumps it right out the front seal..
06 sierra denali 6.0 max
66 grand prix 389
00 caddy escalade 5.7
95 riviera supercharged 3800
85 park avenue 3.8
86 trans am 5.0 tpi
