99 Zx2 91k Miles.
Where Is The Power Control Module? Whats The Average Cost? I Have A Problem With My A/c Not Working. Worked One Day And Not The Next. Also My Coolent Fan Is Always Running(car Never Gets Above Cold). I Think The 2 Are Related. Thanks Tim |
Re: Power Control Module
under the center console.
-Josh- 96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel 98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp. 01' Chevy Blazer, DD. |
Where is a good place to pick one up at? What can I expect to spend?
Is it plug and play or do I need to have it programed? |
junk yard...about $30-75
ford...$350-400 and a you need to kno if you ahve a 99 or a 99.5 9there was a wire change in the middle of the year. How do you know its not the ccrm?
FORMERLY: zx2srdotnet(1,380 posts) 2001 Esxort ZX2 - Traded 2000 Escort ZX2 S/R - Sold 2003 Mustang Mach1 - Totaled 2014 Altima 2.5 S - Purchasing Soon |
When you say ccrm, is this the climate control relay module?
Do you know a easy way to tell if i have 99 or 99.5. The only reason i think its the pcm is from reading posts. Other then that i have no facts. |
the 98-99.5 is a 4wire mass air flow sensor
the 99.5+ is a 6wire MAF
I have opened up the ccrm and found a pin with a bad solder per some other forums have noted. For now my AC is finally working and my fan is working as intended. My olmy problem now is the temp still never gets much above "C". It seems im back to square one.
Does any one know what the temp for a factory oem thermostate is. I did change it back when the problems first started and maybe the guy at the store gave me the wrong temp. |
im not sure what stock is..but i do know a 180* will not cause any problems
With the 180 deg. is your temp in the mid range?
its sits a little lower, i think the stock is liek 190 or 200, my temp sits at little under middle and i have the stock part.
