Old 02-05-2006, 04:59 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Help please...trans issue
I got in the truck today and fired her up as usual (2000 Blazer 4.3L 4WD by the way) and Check engine light came on. Took it to the local Autozone to have them scan the code and it came up as a Shift solenoid.
What is the deal? The haynes manual doesn't cover it and I have no flippin clue where to begin. Is it a pros job or just a weekend afternoon with a lot of busted nuckles and a 12 pack? Any help please!!!!!!!
Old 02-05-2006, 06:21 PM
old_master's Avatar
Advisor/Moderator
Re: Help please...trans issue
Shift solenoids are not difficult to replace. The pan needs to be dropped to access the solenoids. The procedure is in the Haynes or Chilton automatic transmission manual. While you've got the pan off, replace the filter also. If you post the P code that Autozone retrieved, we can figure out which solenoid or solenoids need to be replaced.
Old 02-05-2006, 07:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Like Old master said. Need P code No.
Also remember the code does not say replace the solenoid or part. It says check it out. Could be one of many things like fues ,electrical circuit, wiring.
Give us that code NO.
MT
MT
Old 02-06-2006, 10:06 PM
BlazinMlew's Avatar
The scanner did give the code for the shift solenoid circuit. I belive the code was P0755 which says Shift solenoid Circuit Fault.
I am taking it to the local dealer tomorrow just do be sure about the extent of it.
Old 02-07-2006, 09:17 AM
MT-2500's Avatar
AF - Advisor
Thanks for the code. But The code 755 is only a OBD11 code.
You need the manf/trans/engine codes to know what solenoid or problem is.
Or in other words you need a good scanner like what the dealer or repair shop has to get to the bottom of it.
Could be solenoid or just electrical circuit or even the computer itself.
Let us know how it goes.
MT
MT
Old 02-07-2006, 11:02 AM
BlazinMlew's Avatar
It is at the dealer as I am typing. I will post a follow up when I get the dreaded afternoon call.
Old 02-07-2006, 11:30 AM
BlazinMlew's Avatar
Well no sooner then I sign off of the computer I get the call from the dealer. Seems as though I have a bad harness to the solenoid, also a bad 1-2 and 3-4 So pretty much it was all messed up. Not bad for parts and labor though only $596. I was expecting to was to give up one of my limbs for it. Should have it back in a day or two so its all good.
Old 02-07-2006, 02:24 PM
MT-2500's Avatar
AF - Advisor
Thanks for posting back on how it went.
MT
MT
Old 02-07-2006, 09:11 PM
BlazinMlew's Avatar
Well guess what, I got it back today. All work completed and even found out what that annoying creaking in the front was. Turns out where I was taking my car for oil changes (CARMAX because I get an associate discount) wasnt lubing the front end like they said they were. The service tech informed me that (in his own words) "It looks like this ball joint hasnt been touched in 50,000 miles) So needless to say I am not happy and will not go back to Carmax for any service to my truck. This is the second time they have either mis-diagnosed or didn't fix what was wrong the right way with me. Not to mention that they also neglected to inform my mom that her ball-joints were bad as well until it was to late.
Sorry to vent just frustrated. Thanks for all the input though on all of this.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
