Old 02-05-2006, 03:01 PM
cc10is cc10is is offline
Radio problems
The stock radio in my 94 3kgt is screwed up. Sometimes its fine, but then just out of no where, it just goes quiet. when it does this, i can turn the volume all the way up and hear the sound, only a bit fuzzy. but then the next day i get in the car, and its better, so it blasts my ears off. I dont know whether its the radio, or the antenna. The tape player works fine. I took out the antenna and hooked it directly into the radio, thinking it could just be the cord that runs between them, but that didnt work either. any ideas?
Old 02-05-2006, 03:53 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Radio problems
Ideas?? Get a new headunit.
Old 02-06-2006, 03:08 AM
Igovert500's Avatar
blue + red light magnet
Re: Radio problems
I don't know for sure what the problem is, but if it is your attenna:
http://www.vr4stealth.com/antenna_mast_replacement.htm
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-10-2006, 04:59 PM
BB1970's Avatar
BB1970 BB1970 is offline
Wink Re: Radio problems
probably the radio, the amp built inside the head unit maybe faulty, i.e overheating through age and once it has cooled down enough it will work again. had this a few times on various cars
treat yourself to a new unit, not worth trying to repair the old one.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 02-13-2006, 09:38 AM
91STT 91STT is offline
3SNJ Pres
Re: Radio problems
sounds like the tuner section is faulty or there may be bad solder joints.
1991 Stealth R/T TT
It looks stock, so it must be.
Old 02-13-2006, 11:51 AM
2old 2old is offline
Re: Radio problems
It's probably a dirty contact on the volume nob/switch...
If you are really stuck for cash and time you can take the headunit apart and trying blasting the dirt out with electirical contact cleaner while twisitng the volume nob back and forth which might give you a 50/50 chance of fixing the problem.
Or taking a soldering iron and trying to find a replacement online in a electronics catalogue (and get raped in shipping)
Or you can spend less then $200 replace it with a aftermarket head unit installed which sounds way better then stock.
Old 02-15-2006, 08:23 PM
KiNg3kGt's Avatar
KiNg3kGt KiNg3kGt is offline
Send a message via AIM to KiNg3kGt
Re: Radio problems
just get a cd player put on it...fuck a stock...i gotta get my 3k radio changed since it was an anti theft shit that if u take out the stock radio it wont work...you only got 2 chances to put in a code for it to work again, but once you blow those 2 chances....shit wont work...it just ses "oFF"...ima get my shit pretty soon..
Old 02-15-2006, 08:37 PM
Stealthee's Avatar
Re: Radio problems
You can reset that. There are a few methods. One you can disconnect the battery, one you can turn your ignition to the on position and let it sit for a period of time. Not sure if its 10 minutes or 30 minutes but you can still have chances to put your code in.
Old 02-16-2006, 01:44 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Radio problems
correct. i had this happen to me. you have to let the car sit with the ignition in the ON position for either 30 mins or 1 hr. i forget which. but that was the first time i locked my keys in the car! haha. happens to the best of us
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-16-2006, 11:17 AM
KiNg3kGt's Avatar
Re: Radio problems
oh, thanks for the info, but ima get a cd player for it instead. thanks anyways.
edit: now that i think about it, i dont even have the code.
