Old 02-05-2006, 12:28 PM
joelwideqvist joelwideqvist is offline
Clear tube
Hi I'm trying to track down some clear tube that has wider inner dimensions than the ones from Modelers' or Model Factory Hiro. I need a tube that would fit a .9 mm solder but at the same time it shouldn't have outer meassurements of more than say 1.3-1.5 mm. Anyone know of a clear tube that fits my description. Modelers' and MFH tube is way to narrow.
best regards
Joel
Old 02-05-2006, 03:59 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: Clear tube
Maybe you can find some clear shrink wrap tubing?
Old 02-05-2006, 06:32 PM
pettercardoso's Avatar
pettercardoso pettercardoso is offline
Send a message via MSN to pettercardoso
Re: Clear tube
One other possibility would be to use clear fishing line?
Pedro
Click the picture to check my progress thread:
Old 02-06-2006, 12:46 AM
robrex's Avatar
robrex robrex is offline
Re: Clear tube
Joel,
Sakatsu make clear tube with outside diameters of 1.1mm and 1.2mm. I have the 1.1 and 0.9 'wire' is a tight fit so the bigger one may suit?
Here's the links to HLJ
http://www.hlj.com/product/SAK4521
http://www.hlj.com/product/SAK4520
Hope that helps?
Rob
Old 02-06-2006, 01:35 AM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
Re: Clear tube
you could just go to radio shack and pick up some speaker wire.
strip the wire out of the clear side and you have perfect clear tubing and tons of it for cheap
Old 02-06-2006, 08:09 AM
Re: Clear tube
thanks
I think I'll try the Sakatsu one, fishing line is perfect for some items but I have to get something for the breather hose on the motorcycle tank and the fitting gets pretty wide.
/Joel
Old 02-08-2006, 06:56 AM
bvia's Avatar
bvia bvia is offline
Re: Clear tube
www.smallparts.com
and do a search for tubing...
hth,
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
