Old 02-05-2006, 08:48 AM
Ranger 1 Ranger 1 is offline
freeze plug removal & installation on a 4.3 chevy
How do you remove and install a freeze plug? Is there some type of sealant used with the install? Thanks
Old 02-19-2006, 08:40 PM
sbc350z71 sbc350z71 is offline
Send a message via AIM to sbc350z71
Re: freeze plug removal & installation on a 4.3 chevy
There is a tool to do it but you can do just as well with a punch and a hammer. Hit the bottom in but becareful not to score the block. When the plug is sideways pull out with a pair of pliers. To install use a big deep socket and hit in the center untill the plug is flush with the block. Good Luck
Old 02-20-2006, 05:32 AM
Bads Crew's Avatar
Bads Crew Bads Crew is offline
I would also run a bead of permatex gasket sealer around the edge of the freeze plug before you install it. This will make it slide in eazier and seal it better.
