Old 02-04-2006, 09:04 PM
jvpwdc jvpwdc is offline
'97 Buick LeSabre
'97 Buick LeSabre, V6 3.8 liter engine was fluctuating between 55 and 70 psi oil pressure @ 70 - 75 mph highway speed. Is this o.k.? If not, what could be wrong ??
Old 02-05-2006, 10:21 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: '97 Buick LeSabre
Yes it is OK! You are probably seeing fluxuation due to oil drain back. At those speeds the engine pumps a lot of oil and it takes a little while to drain back to the pan. 55 psi is fine and the fluxuation is normal.
Old 02-05-2006, 03:10 PM
maxwedge maxwedge is offline
A990 racer
This can also be caused by too much oil, causing aeration and consequent pressure fluxuations, a bad sending unit has also been known to cause this Ordinarily the oil pickup is constantly submerged, so these other issues should also be looked at.
