| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
i pulled the codes p0740-"TCC Circuit Malfuntion"
What the hell is a tcc? i cants find a match anywhere? is it expensiv, and easy to fix? I really appreciate any help anyone can give me. Thanks. |
Re: Got Codes for repair..know what??????
p0740 torque converter clutch. its actually a transmission code but will set in the engine ecm. what year, body and engine do you have? most of the time your gonna have to replace the solenoid pack on the valve body inside the tranny.
Its a 1997 Maxima with a 3.0 liter v6. GXE. if you could help, i would really appreciate it.
Thanks already for getting back to me. |
If problem is constant, you may measure &verify each solenoid resistance with a multimeter. The solenoid resistance values you find in FSM. Look below, zoom into 'Favorite Links' Most probably its bad oxidized contact(s) meaning low voltage at TCU Transmission Control Unit, and/or low voltage =starved solenoids.. Check p.14 & 10. Verify also if bad TPS signal; measure all ctrl voltage levels at TCU pins, also found in FSM (and p.15 TCU pin list.) As always, start from checking charge voltage.
. Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507 ![]() There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14 |
there is a recall on the solenoid's for certain vin#'s. need to call nissan at 1-800-nissan1 and give them your vin# (tell them you want to check for outstanding campaigns on your car)and hopefully your car is within the vin range. if so, it wont cost you a dime.
Recall, listed in TSB's. Seek uself for all Nissan Tech bulletins:
http://maxima.theowensfamily.com/tsb/ (One A/T related TSB: NTB96-110 http://maxima.theowensfamily.com/tsb/NTB96-110.pdf) |
i checked with nissan and mine has been recalled. thanks for the tip....you have no idea how much trouble you saved me. thank you so much.
