Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-04-2006, 04:42 PM
lil_red_ex_neon's Avatar
lil_red_ex_neon lil_red_ex_neon is offline
Send a message via AIM to lil_red_ex_neon Send a message via MSN to lil_red_ex_neon Send a message via Yahoo to lil_red_ex_neon
no balls off the line ?
I have a 97 neon sohc and ever since I have had this one it has had no power from a dead stop up to about 15-20 mph, when already moving it has about the amount of power as it should, but nothing off the line. it is a automatic trans. I am about to perform a compresion test and check the kickdown band but I'm not sure if those could cause this problem. if you have any advise it would be appreciated.
thanx
Old 02-05-2006, 10:08 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: no balls off the line ?
Welcome to the crappy world of the ATX neon. There is probably nothing wrong with your compression, it's just that the ATX neon does not perform great from a stand still. There are some things you can try to help, like prothane inserts, install a shift kit, install a high stall converter, transfer gears, and a manual valve body. Unfortunately the ATX neon isn't very quick and can be outperformed by the MTX easily. Thats why alot of people swap in the MTX into their neon and instantly get quicker.
Old 02-05-2006, 03:39 PM
that what everyone says I know its true, but this is worse than it should be, I have driven numorous other ATX neons before and the power is nowhere near it should be, no torque at all. I am planning on swapping it to a manual, but would like to find out where this problem is coming from first. I brought it to a dealership, but got little help. I'll update you with the compression stats, as soon as I can get to it
thanx
p.s.
maybe the ECM?
Old 02-08-2006, 01:05 PM
Originally Posted by lil_red_ex_neon
maybe the ECM?
I don't think the ECM has anything to do with the trannies on the first gen neons. But who knows? Try the compression check and you can probably get some answers fromn there.
Old 02-09-2006, 02:34 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Ever done a tuneup?
The Champion plugs should be changed every 15k-20k.
My ATX is quite peppy off the line. It is the 1-2 shift change is where it bogs.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-09-2006, 07:35 PM
well I did the compression test and this is what I got...
cylinder.. 1 2 3 4
compression... 190 200 190 200
then I added oil to check out the rings...
cylinder... 1 2 3 4
compression.. 265 240 .... ....
......then I blew an O-ring on the tester.
so the rings could be worn, but I think i added to much oil, so im not sure.
what is a healthy compression in a neon?
im gona check the fuel system (filter, injectors) and see if I can come up with somthing there. and then try and check every vacume line, I know I need to change a few emmisions parts , so maybe thats where the problem lies
Old 02-09-2006, 08:53 PM
BlazerLT's Avatar
AF -Advisor
Your first numbers are accurate, compression numbers are not taken by adding oil.
Good compression actually.
Old 02-11-2006, 04:07 PM
the oil is used to test the condition of the piston rings, its just a way of narrowing down your possible problems. but I used to much so it wasnt accurate anyway.
Old 02-11-2006, 06:41 PM
BlazerLT's Avatar
AF -Advisor
Your compression is really good for that engine.
Can't complain with those numbers.
Old 02-12-2006, 04:38 PM
thanks thats good to know.
yeah I have done a tune up, I checked fluids, changed some. replaced stock air filter with CAI. replaced vacume lines, spark plugs, ect....
still would like to get new coil and plug wires
I found some problems witht the Evap system, so im hoping thats all it is. wont have any extra money for like two weeks but then I should be geting a new evap purge selenoid, new lines, and maybe a new charcoal canister.
also I am doubting my iac valve, so I think i will replace it also.
ill update if I have any success
Old 02-12-2006, 04:48 PM
BlazerLT's Avatar
AF -Advisor
I would replace your IAC, just take the intake hose off of the throttle body and get and old toothbrush and spray the butterfly down with a little cleaner and scrub the top and underside.
Also spray cleaner into the IAC hole above the butterfly to dissolve any crud.
I hope your went with standard Champion plugs.
Old 02-12-2006, 05:05 PM
I know I should have used champion, but I tried splitfires this time.
yeah I have already cleaned the TB and IAC, but still no change. the IAC just seems to not be working.
Old 02-12-2006, 05:32 PM
BlazerLT's Avatar
AF -Advisor
oh,,,,my...god....
get those splitfires out and take them back.
Worst plug in the world.
NEVER EVER use them.
There is your performance problem right there.
No wonder, those plugs are junk.
Old 02-14-2006, 12:04 AM
oh,,,,my...god....
I know, I dont like them. but the problem was there even before I replaced the champions.
Old 02-14-2006, 12:12 AM
BlazerLT's Avatar
AF -Advisor
Wel you won't be finding the real problem with defective plugs for sure.
What gap were you setting the champions too?
