Old 02-04-2006, 04:41 PM
baibai baibai is offline
FireBird Headlight Problem (not gear)
I finally got my headlight motors to at least work by replacing my headlight module. but now I am having a strange problem. One light goes up while the other one goes down. The passenger side light seems to be on the right cycle (up when on, down when off) but the drivers side is doing the same thing. Does anyone have any idea what could be wrong?
Old 02-06-2006, 12:50 PM
Re: FireBird Headlight Problem (not gear)
still looking
Old 02-06-2006, 12:54 PM
83T/A98Blazer 83T/A98Blazer is offline
I've not encountered this problem but there must be some wires crossed somewhere. Is there any way to reverse the connector at the headlight motor?
Old 02-06-2006, 01:00 PM
CreepingDeath94 CreepingDeath94 is offline
Also, is it possible something got reversed when you installed the new module? Im not sure exactly what is involved in that job or if it even possible to reverse something, but thought Id throw it out there.
Old 02-06-2006, 01:16 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
the reversing the wires should work.. try use alligator clips and cross it, see if it works and if it does, eithier flip it somehow or cut and crimp the thing
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 02-06-2006, 01:33 PM
crossed wires could be a possibility because when I bought the car the motor on that side never worked. There also was really a very hack job to try to get it to work. I'm not an eletrician by any standards but won't crossing the two wires be wrong because one of them is the ground and one of them holds a current? I don't know am I wrong?
Old 02-06-2006, 03:42 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
That's true. I would never suggest to anyone to put the main power feed to the motors ground wire, and the main ground wire to the motors power feed. What I would recommend doing is turn the headlight switch to the on posistion, go to the headlight that isn't flipped open, use the manual control knob on the top of the motor, and turn it until it is open. That way both headlights will be open, then try turning the switch off and back on to see if both your headlights are on the same sequence. If that doesn't fix it, then I would have to guess that you bought the motor for the other side headlight, and basically just installed it upside down. Each side has a different motor, they are identical, but one faces one way and the other faces the other way. So if you ended up putting the wrong motor in, then that could explain why the light is going up after you turn them off. Just my guess.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 02-06-2006, 04:42 PM
This doesn't work and it was the first thing i tried. The motor that I have seems to be the motor that the car came with. The way the motor works I THINK (based on a little research) is that the motor knows which way to turn by the direction of the current coming in. So there is something wrong with the current coming in. I didn't buy the motor it came with the car. I bought a module.
Old 02-06-2006, 05:36 PM
blindeyed's Avatar
eBay aDdict™
This doesn't work and it was the first thing i tried. The motor that I have seems to be the motor that the car came with. The way the motor works I THINK (based on a little research) is that the motor knows which way to turn by the direction of the current coming in. So there is something wrong with the current coming in. I didn't buy the motor it came with the car. I bought a module.[/quote]
Well as long as the red wires and black wires are meeting, then I would believe that you have it installed right. From my experience of working on electronics, when you meet the positive to the ground, and vice versa, normally nothing would happen. I guess you could try switching the wires and see if that does the trick. I guess logically it could work, I've never had to try to be honest.
- Jason
Old 02-06-2006, 06:11 PM
tri-power's Avatar
tri-power tri-power is offline
It is possible to have the wires reversed. The current passes in both directions to direct the motor to turn the correct way. The current travels one way to lift the bezel and then travels the opposite way to lower the bezel. The best way to check that the current is travelling the right way is to take a volt meter and test both sides. Test the passengers side first because it's the one on the correct pattern. Then test the other side. If the drivers side polarity is backward, then cut and reconnect the wires accordingly.
Old 02-06-2006, 07:28 PM
Thanks a lot that is exactly what I wanted to know. I will try to reverse them and see what happens! I'll let you guys know tomorrow. I want to thank everyone again for all their help because I really appreciate it!!
Old 02-07-2006, 06:32 PM
driftinggrifter2's Avatar
driftinggrifter2 driftinggrifter2 is offline
Send a message via AIM to driftinggrifter2 Send a message via MSN to driftinggrifter2
I would say this is the most likely problem. Never encountered this before but it sounds themost likely.
F-Bodies Forever Member #2
guess bunny couldnt dominate the world!
Old 02-08-2006, 01:01 PM
Yep somehow, the wires were reversed. I cut into the ones connecting to the motor and switched them around and it works correctly now. I wish I could've just taken them out of that white connector but they wouldn't budge. Works perfectly now, thanks.
Old 02-08-2006, 02:17 PM
tri-power's Avatar
It's possible that the wires on the motor were wired backward, or like you said, your wiring was fudged up. Reguardless, you can reverse dc motors.
Old 02-08-2006, 05:31 PM
hmm..to cover my ass, i meant cross the wires after you took it off the MOTOR. the motor has a + or - input and its not grounded...since it has to reverse directions to open/close..
so, remove the connector to the motor,
get two wires w. alligator clips
send one to the + side and other to - side, try it out, if it does the same thing, flip/cross em..if that works, wire it that way..somehow..
Car:
285's in the back
all else = STOCK.
