Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 02-04-2006, 03:12 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
75 280z, Black Smoke! (carcomusa)
Originally Posted by carcomusa
HELP!!!! i have a 75 280z......it is fluttering, blowing black smoke out the tailpipe-smells like gas. the car is choking cutting off. we changed the plugs, MAF, computer, fuel pump, fuel regulator, plugs, tps. checked the lines-fuel pumps in fine, fuel filter is new. Are we missing anything obvious ( or hidden for that matter. If anyone has a possible solution we are all ears!!!
moved to its own thread...this is a thread for you to diagnose your own problem, if this doesnt help then you can start a new thread.
ZedEx Crew Member #4
Old 02-04-2006, 03:17 PM
Z Cars Fanatic
Re: 75 280z, Black Smoke! (carcomusa)
ECU?
your car is running EXTREMELY rich...
Old 02-04-2006, 03:25 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
did it just start doing it? what's the story behind the car? was it sitting for a long time?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 02-04-2006, 04:57 PM
jsb5717 jsb5717 is offline
I'm sure you've checked but almost sounds like incorrect firing order. It's easy to have it wrong, change the wires, plugs, or cap, and keep it wrong.
Old 02-07-2006, 10:26 PM
billszcar billszcar is offline
It sounds like your Timeing is off.
The same thing happend too me and i found the rottor was off 180 deg.
