Upper ball joint
OK, I should know this but it eludes me...when replacing an upper ball joint (96 blazer) does the ball joint and bolt pattern get placed under the upper control arm or on top and through it...thanks in advance
Re: Upper ball joint
How was the old one mounted?
If I remember correctly, the new joint goes down through the control arm from the top, but the bolts come up from the bottom. Mine is a 98 but should be the same.
On my 2000 it went through the top, not on the bottom. Hope this helps. Also might want to consider doing the lowers while you're getting dirty and swearing.
![]() I hope this is big enough to see. |
1st thanks for all the replies guys. the old one I took out was in two pieces it went down and then a flage for lack of a better word went under it and is sandwiched on the control arm.. new one is all one piece...by the looks of the diagram it goes through the top, looks like I be working on the blazer before the game. (did the lower also, thanks)
http://www.imagestation.com/album/pi...869&mode=guest
![]() 1998 GMC Jimmy 4X4 1999 Grand Prix GTP (Nice!!) 2001 Saab 9-5 |
billibong 99 4X4 Blazer LS Vin W Repairs: U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference) F & R Brakes and Rotors at 110,000. Infinity Speakers to replace the blown factory sets. 162K+ and still kicking. |
Great link,informative and amusing! Good job!
2000 Blazer 4WD 2Door http://www.cardomain.com/ride/2324297 06 Pontiac G6 V6 Coupe http://www.cardomain.com/ride/2371527 |
Cheers!!
