98 caravan ignition lock cylinder
I am loking for help with a 98 caravn.I am replacing the ignition lock cylinder because it is locked up.I can not get the cylinder to return to the acc.position to remove it.Does anyone have any tricks for doing this to get the old switch out?
Re: 98 caravan ignition lock cylinder
Jack of all trades...Master of none! Could someone please fix my Instant Email Notification? Please get back to us with your fix! Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
I have seperated the electronic switch from the mechanical so as too start van and drive home.I have tried all 3 keys for the van and all are the same result,no turn.I would like to know if there is an easy way that someone has found to remove a non turning cylinder from the housing.
Thanks for replys. |
Problem is solved.I ended up drilling into the safety catch that holds the cylinder in and the tumblers freed up enough to turn and release the cylinder.New one is installed and set to go.
98zr67, Where can I find this side bar to drill it out. I need to remove the lock cylinder for my 92 Voyager.Thanks!
