Old 02-04-2006, 11:34 AM
blisk323's Avatar
blisk323 blisk323 is offline
Rear Disc Brake Conversion
Would it be a good idea to do a rear disc brake conversion on a 1991 Honda civic Dx? What other civic than an Si can i get it from?
[IMG]C:\Documents and Settings\David A. Toj\My Documents\My Pictures\CameraPics[/IMG]
Old 02-04-2006, 05:25 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: Rear Disc Brake Conversion
Basically any Civic/Integra trailing arm from 88-00 will bolt in if u use your stock LCA and the front bracket... I used 91 Teg trailing arms on a friend's Del Sol, fit like a charm... The guy just had low pressure in his brake, so make sure u use a proportioning valve from a rear disc brake Civic/Teg aswell... We never got around to doing that on his... I havnt talked to the guy much since (he lived in New orleans so hes been kinda busy getting his live back together after Katrina) so I dont know if he ever got that done or not... Youll also need the emergency brake cable from a car with rear discs...
